My A/C won't start all of a sudden
Damdifino
I spent the past week camped on the beach in Port Aransas with high temps and humidity. I ran the A/C with a MicroAir EasyStart installed 24 hours a day off my Honda 2000 with aux fuel tank. Everything performed flawlessly. But when I got home and hooked up to my 30 amp shore power, the A/C won't start. It acts like it's tripping the breaker, but the breaker isn't tripped. I tried running off the generator again, and same thing. I haven't got a clue where to start trouble shooting. Hoping you good folks have some thoughts...
2014 Arctic Fox 22H.
2009 Toyota Land Cruiser URJ200 Series
11 REPLIES 11
SoundGuy
BillandCarole wrote:
How in the world did you get your AC to run of a Honda 2000?
Read the OP's post again - he's equipped it with a Micro-Air Easy Start Soft Starter Kit.
2012 Silverado 1500 Crew Cab
pianotuna
Nomad III
Nomad III
The microaire does come with a large capacitor
Regards, Don
sayoung
ScottG wrote:
I would look for a failed start capacitor.
That's most likely a bad RUN capacitor, that micro air thingy might have a start cap . Caps fail like crazy in high temps & low current/voltage situations. Run cap is wired between the run & start windings. Once the compressor & fan gets to about 70 to 80 % of working rpm its not needed any longer until unit try's to start again. Compressor probably tripping overload , just a WAG on my part
BillandCarole
How in the world did you get your AC to run of a Honda 2000? Our 12K BTU AC took 2 of them, and then they "screamed" even in eco mode and drank fuel like they were dying of thirst.
My Experience
Bill
2K8 Chevy LTZ Turbo Diesel 4x4
Cats Vino, and "Stubby"
Transfer Flow Tank
2017 Fox Mountain 235RLS
Reese 16K Slider
Honda EU2000's to power the toys
Garmin GPS's/Android Pixel 2XL -WAZE
"And were still wandering..."
Damdifino
I appreciate the suggestions and I'm working through them as best I can. Please keep 'em coming. OP
pianotuna
Nomad III
Nomad III
Regards, Don
pianotuna
Nomad III
Nomad III
Hi,
How low did the voltage get on the generator?
Regards, Don
SoundGuy
Any chance one of the Micro-Air spade connectors has come loose?
2oldman
Try without the Microair.
BB_TX
Did you try turning the breaker off and back on. It is not always visually apparent when a breaker is tripped.
ScottG
