โApr-15-2022 07:30 AM
โApr-24-2022 09:45 PM
โApr-24-2022 09:39 PM
โApr-24-2022 09:18 PM
โApr-24-2022 07:56 PM
pianotuna wrote:
Hi Itinerant1,
Any idea of the daily consumption numbers over a month in January and in July?
You have one heck of a good system imo.
โApr-24-2022 10:31 AM
โApr-24-2022 08:54 AM
โApr-24-2022 08:03 AM
โApr-23-2022 02:04 PM
โApr-23-2022 02:02 PM
Cptnvideo wrote:10 minutes absorption at 13.8 volts, float 13.2, equalize every 3 weeks at 14.2 volts 30 minutes.
New to LFP batteries. For those with LFPs and solar, what is your float and absorb charge voltage set at?
โApr-23-2022 12:38 PM
โApr-18-2022 09:07 AM
pianotuna wrote:Yes very possible. However probability is slim to end up with the exact range needed to get home. Invariably will be 10+ miles short or 10+ miles long.
If one is returning home--the charging would certainly allow maximum range to be used, as that's where the majority of charging happens. So the majority of the time nearly 100% range is quite possible.
โApr-18-2022 08:50 AM
StirCrazy wrote:
camping in BC is not like camping in California, becasue of the trees you might only get two hours of good sunlight a day and need to take advantage of that.
โApr-17-2022 06:52 PM
BFL13 wrote:
Good info by itenerant1 and implied advice to other LFPers. Stay far enough above the lower knee and never mind about not using 100% capacity. Monitor!
โApr-17-2022 06:50 PM
Itinerant1 wrote:BFL13 wrote:
StirCrazy note that more solar will not save you if sky is overcast. LFP does not change need for gen as back up. Portable gen but not built in is also recovery method for LVD
So true all the extra solar does is allow you to run more items from it and give the batteries a break on the side line waiting for the coach to call them into play when needed while possible still being charged to some degree or after being charged and floating the solar is running the loads if you have enough solar to cover the loads. But when there are multiple days of poor solar or just use alot of power like I do it helps to have a backup plan for charging.
โApr-17-2022 06:46 PM
