My New LED Light Bar Specs
MEXICOWANDERER
SPECIFICATION :
1.LED Power: 400W
2. Operating Voltage: 9-32V DC
3.Waterproof rate: IP 68
4.80pcs*5w high intensity LEDS
5. Body Color: White
6. New Cree Convex Lens
7.Material:Material: Hi-impact Aluminum Housing
8.Lens material:PMMA
9.Mounting Bracket: Stainless Mounting Hardware
10.Life Span:50000H
11.Dimensions:42inch
12.Amp Draw(DC):33A /12V , 17A / 24V
13.Beam Type:: Spot &Flood Beam Combo (12F/56S/12F)
14.Theoretical Lumens Output: 40000LM
15.Operating Lumens Output: 36000 LM
16.Weight: 6kg (Per Unit Included The Box)
17.Size:1059x88x78mm
18.The high performance of tight waterproof,dustproof,quakeproof.
19.Anti explosion
Naw, it ain't a joke. New technology OSRAM chips. Gotta feed this mutha with 10 gauge wire. An 80-ampere TYCO relay is on the way. The light this bar produces is insane. No using in hilly or curvy conditions. Dim lights when oncoming car is 2 miles away (another - not a joke). Dang near weaponized lighting.
18 REPLIES 18
GordonThree
100lm/watt sounds about right for "new" chips. I wonder however is the rating in ANSI lumens or Peoples' Republic most-honorable lumens?
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
MEXICOWANDERER
gbopp
Is it built or, still in the planning stages?
intheburbs
No pics?
2008 Suburban 2500 3LT 3.73 4X4 "The Beast"
2013 Springdale 303BHS, 8620 lbs
2009 GMC Sierra 1500 Denali (backup TV, hot rod)
2016 Jeep JKU Sahara in Tank, 3.23 (hers)
2010 Jeep JKU Sahara in Mango Tango PC, 3.73 (his)
