With all the inefficiencies in the conversion processes, it seems to me terribly wasteful to use an inverter to convert 12 VDC to 120 VAC for a CPAP, which will then convert it back to the 12 VDC that it runs on. It is so easy to find the correct machine what will run directly off of 12 VDC using only a cord which costs $25 or less.
In pondering Wrace's experiences from 1988 and today . . .
Sleep apnea seems to be diagnosed a lot these days, and treatment for it is thus a booming business. I suspect that it was under-diagnosed previously. I suspect that I have had OSA since at least my teenage years. I suspect that my father had OSA and would have lived far beyond his 57 years had he been diagnosed and effectively treated.
Because sleep apnea is more frequently diagnosed these days, it has become a bigger cost item for insurance companies; therefore, the insurance companies are looking for savings. All manner of terms are included in policies to reduce costs to insurance companies, including for treatment of sleep apnea. When insurance companies negotiate contracts with providers, they are also looking to minimize their costs. So when receiving substandard service from providers, Iโm not sure how much of it is the fault of the provider trying to minimize their costs or how much of it is due to the insurance companies ratcheting down the amounts they pay to providers.
My own decision was to take charge of it myself. For any of you out there who are unhappy with the service and equipment youโve gotten, you may be able to do the same. There are many companies on-line which will sell you the CPAP/BiPAP you want, and the prescription does not need to specify the particular machine. The machine you receive will be set to pressure and other parameters in the prescription, but if the pressure needs changed, the Clinicianโs manual is usually easy enough to find โ some sellers donโt remove them from the package before shipping, or many can be found on the internet.
My biggest problem was that I was titrated at 13 cm, which I could not tolerate well. It was continually waking me up, which negated the benefits. Had this been my only choice, I probably would not have continued using it. I learned the availability of auto-titrating CPAPS and so I bought one of those years ago. It arrived set at the prescribed 13 cm; I re-set the pressure to a range of 10 cm minimum to 14 cm maximum.
I was able to obtain the software for reading the data from the CPAP and make necessary adjustments to minimize the number of apneas and hypopneas I was experiencing per hour. In those days, the software was not generally available and I was very lucky to get it. These days, the software for reading data many machines is readily available from on-line dealers and does not require a prescription.
Your problems and solutions may be different from mine, but I encourage everyone who needs the therapy to work on finding the solution that works for you, rather than discontinuing use of any therapy at all because of a bad experience the first time around.
Wayne
Wayne & Michelle
1997 Safari Sahara 3540
