โDec-06-2018 02:42 PM
โOct-19-2019 04:39 PM
โAug-30-2019 09:37 AM
โAug-26-2019 06:32 PM
โAug-26-2019 04:18 PM
โAug-26-2019 09:20 AM
MrWizard wrote:
Decimal place does NOT Float , it was
006.5 amps
Not 6.500 amps
Resolution , is 0.1 amps, aka 100 ma,
No it won't show 0.043 amps
Aka 43 ma or 0.430 amps aka 430 ma , it will display 000.4 amps
โAug-26-2019 07:32 AM
โAug-26-2019 05:08 AM
GaryS1953 wrote:LittleBill wrote:I haven't got mine programmed right yet, but it DOES show a decimal point. Not sure how accurate the reading is though.GaryS1953 wrote:LittleBill wrote:Hi Bill,
did anyone buy the 200 amp shunt? or do you all the 100 amp version, i have tried all over the place but no one will tell me if the 200a shunt will measure milliamps.
I have the 200 amp meter, but unless I'm mistaken, the meters in this thread only use a hall sensor, not a shunt.
does it show a decimal place? or does it only read in full amps? im looking to see if it reads milliamps
i mis spoke i meant the hall sensor.
MrWizard wrote:
meter display right NOW
006.5 amp discharge
(1) decimal point , xxx.1 to xxx.9
โAug-25-2019 10:24 PM
โAug-25-2019 06:42 PM
โAug-25-2019 06:38 PM
K_and_I wrote:K_and_I , thanks, good to know.GaryS1953 wrote:
I have one more question. My sending unit has the cables on the end that go to the hall sensor, but it also has one long black cable that doesn't seem to be addressed in the bad copy of the instructions that I have. Any idea's on that? Temperature sensor maybe? If so, where does that connect?
If I'm not mistaken, that is an antenna for the wifi connection between the board and the meter. I just wound mine loosely around inside the weatherproof box.
โAug-25-2019 06:35 PM
โAug-25-2019 04:42 PM
โAug-25-2019 04:30 PM
