โJun-15-2016 10:27 AM
โJun-20-2016 05:54 AM
โJun-19-2016 05:08 PM
myredracer wrote:dclark1946 wrote:
My thought was to initially either change to the other model TV antenna that supports AM but requires another coax line to be run above the ceiling (no idea how big a problem that will be) or add a conventional whip antenna to fix the AM reception issue.
Running wiring/cables through a ceiling and inside interior walls is pretty straightforward. I've also done it in the same model of Spree with romex, coax, HDMI & low voltage wiring from the front to the rear of our Spree and can tell you exactly how and where to run it. Let me know if I can help you.
โJun-19-2016 01:53 PM
โJun-19-2016 08:48 AM
Lynnmor wrote:
You really need to forget about that brand of antenna. As you know, the antenna is omnidirectional, and will give poor performance with the TV as well. It was installed because it was the cheapest thing that could be found and it looked like a real antenna.
โJun-19-2016 06:03 AM
โJun-19-2016 05:49 AM
wa8yxm wrote:dclark1946 wrote:
Our trailer is fiberglass with all aluminum frame same as our previous trailer. The receiver has a Motorola antenna jack fed from the external TV antenna with an RF splitter or perhaps diplexer feeding the radio antenna jack.
That tells me everything I need to know. The TV antenna is tuned to VHF/HUF not to Am broadcast. It is a very poor choce for AM Broadcast
IF you like AM radio, Get the longest Automotive antenna you can lay your hands on and install it. The longer the better..
For FM. it may work, or you can switch back.
โJun-19-2016 05:34 AM
John & Angela wrote:
Soooo, You know for sure there are AM broad casters in your area? The last one in our area shut down about 8 years ago. Just sayin, maybe check with another radio.
โJun-19-2016 05:21 AM
Joe Way wrote:dclark1946 wrote:
Joe,
That antenna looks pretty interesting. Do you know if the description that it swivels 180 deg. means it will lay down on the roof?
Well...it looks exactly like the one on our current RV, which does lay flat. Looking closely at the detailed photos, I feel quite comfortable in saying it does lay flat.
โJun-19-2016 04:49 AM
โJun-18-2016 06:12 PM
dclark1946 wrote:
Joe,
โJun-18-2016 04:55 PM
โJun-18-2016 02:59 PM
Joe Way wrote:
Most car radio antennas have a clamp arrangement that bears against the underside of the fender. Most RVs need an antenna with a mounting flange. Here's one on eBay.
The RVs we have owned all had radios built like car radios, with no internal antenna.
โJun-18-2016 10:49 AM
wa8yxm wrote:
Ok, since I do not know your trailer.. What is it made of (Siding?)
AM radios will not work well inside a metal can.. (ALso known as a Farady Cage) it is possible to make them work but you need an OUTSIDE antenna to do it.
Ideally about 75 meters of wire, wrap twice around radio, ground one end, toss the other up over trees..
In practice even 30-50 feet will work or less. Just get it OUTSIDE teh trailer
There are also several portable High Performance AM radio antennas you can couple to the radio, Some can be "Remoted" (put outside the trailer) for improved performance.. I suggest a Google Search.
โJun-18-2016 05:01 AM
