No headlights problem please help
jay_kinsaul
So I just got a 1984 pace arrow in like new condition and everything but the headlights are not turning on. The switch apparently works cause I can turn on my running lights and dash lights and it dims like it should just no headlights at all. I have even tried hitting the brights switch on the floor and it don't do anything either not even the lights for bright for brights light up. So none of the four headlights work dims or lows. Any pointers and advice would be greatly appreciated
16 REPLIES 16
Roger10378
For safety reasons all headlights are on self resetting circuit breakers. Most of them are part of the switch.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
allbrandauto
Grit dog wrote:
allbrandauto wrote:
most chevys used a fusible link at the starter motor
For the headlights? Don't think so.
70s/80s GMs and probably other mfgs, power supply to the headlights goes straight through the switch. (The reason they make cheap relay harness kits now to boost power to the headlights)
Most likely is a failure in the headlight switch itself (I think?)
but trace power in and out of the switch to verify that.
RLS7201
Do you know how to remove the headlight switch? Pull knob all the way out, get your fingers on the back side (flat side) of the switch and push the little spring loaded button and then pull the knob out. Then you can undo the nut that holds the switch assemble in place.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Grit_dog
Navigator
Navigator
Or, old GM headlight switches are so cheap, just slap a new one in and see if it works.
If it's the same as the cars and trucks, there's a little trick to getting the knob to release. Easier for you to look it up than explain.
Grit_dog
Navigator
Navigator
ROBERTSUNRUS
RLS7201 wrote:
Matt_Colie wrote:
Jay,
You don't say what the chassis but most have the headlights on a separate fuse that is in the fuse group. Now you just have to find it and hope it is bad and that is all that is wrong.
Matt
Headlights are NOT fused. The lead for the headlight switch comes straight from battery power. The headlight switch does have a circuit breaker built in.
The headlight switch does have separate circuitry for the headlights and the parking/running lights. So the switch may be bad, even if the running/dash lights work.
You need to get out your VOM and check for voltage all along the wiring path for the headlights.
Richard
๐Ÿ™‚ Hi, this is the correct answer; Also when you remove the headlight switch, look for a melted connector.
๐Ÿ™‚ Bob ๐Ÿ™‚
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
Lwiddis
This was a classic purchase on your part. Congratulations!
jay_kinsaul
Yeah it's crazy how good of shape this thing is in it's like a time capsule. The carpet is like new and all the original appliances still work. Has 23,000 miles on odometer and 49 hours on generator. Changed the fuel filters and now runs and stops great for $200
wa8yxm
There may be a fuse or breaker.. There may also be a relay in the main chassis fuse box (or elsewhere)
True story... My 8.1L Vortec (Chevy) engine would not crank (starter not engaging) I heard a sharp CLICK. not a CLUNK but a CLICK.
Pulled the starter pilot relay out of the fuse box.. Cleaned contracts. (I have the tools for that) replaced. Varoom.
allbrandauto
jay_kinsaul
I will have to check that next time I go to it. I hear the switch work but like I said the blue light indicator for brights don't come on
Krusty
Nomad II
Nomad II
Check for power at your high beam switch with the headlamps on. Should have 12 volts going in and it'll have 12 volts coming back out on either the high beam circuit or the low beam circuit. Also check the connector down there for corrosion and wires broken off
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
jay_kinsaul
It's got the Chevy chassis wit the 454. I saw somewhere on Google that there's a circuit breaker on the switch itself
RLS7201
Matt_Colie wrote:
Jay,
Matt
Richard
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
