No power to fridge and ac unit and no dc lights
kmreyno
We had a damaged power cord repaired it everything working great for one day then one ac and fridge won’t work power is getting to fridge outlet it’s not even switching to gas no lights at all. Also ac is not comfortable on. The dc lights are not working now. We have a new converter and a new and charged up battery. All fuses and breakers have been checked and working. Any ideas
5 REPLIES 5
Old-Biscuit
Back on 12/29/2017 you posted issues with SMOKE from breaker panel....but you never replied to the questions asked in that post about source of AC power etc.
Now you have more problems.
Can't help when you don't follow up
Sam_Spade
Check that again. Most (but not all) of your symptoms could be caused by failure to distribute 12 V.
Fridge requires 12 V, so does thermostat probably.
If you don't have a multi-meter to chase voltages, NOW would be a good time to get one.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
enblethen
Check the reverse polarity fuses o the converter if equipped.
Check for circuit breaker adjacent to the batteries
Cycle your battery disconnect
EDIT Battery disconnect should not effect operation when plugged in.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Germania
Sounds like a DC problem, check on your DC Dist panel with a voltmeter for the presence of 12v. I
f none present work way back towards battery to find problem.
sayoung
50 or 30 amp ?
If 50 one leg of hot open maybe.
