โJul-11-2023 01:36 PM
โJul-12-2023 03:07 PM
โJul-12-2023 10:53 AM
Gottahaveit wrote:
It's a long shot but once our fridge would not work on A/C and the GFCI plug in the bathroom was tripped.
โJul-12-2023 10:51 AM
dougrainer wrote:
Are talking you had a 30 amp plug installed or a 50 amp? Reverse polarity should NOT have blown the refer 120 volt fuse. BUT, you need to check for 120 on EACH SIDE of that 7.5 amp fuse. Use ground for 1 probe and the other on each side of the spades while the fuse is plugged in. Make sure the refer power cord is correctly installed on the control board and snug. Doug
โJul-11-2023 10:33 PM
โJul-11-2023 04:58 PM
โJul-11-2023 02:16 PM
opnspaces wrote:
Get a multimeter or a small 120 volt item (radio, fan, table lamp etc) and plug into the 120v outlet in the refrigerator compartment. Is there power at that outlet?
โJul-11-2023 02:07 PM
