โJun-13-2015 09:29 AM
โJun-14-2015 08:11 AM
dougrainer wrote:So what may be the problem Doug? You have a lot more experience with this stuff than I do.Gillkid wrote:
A general idea where the thermostat is?
The tstat will not be a factor if the refer operates on LP but malfunctions on 120. Doug
โJun-14-2015 05:29 AM
โJun-13-2015 08:09 PM
โJun-13-2015 07:06 PM
Big Kahunna wrote:
The unit is a 2011 but I don't know the model number.
As I said before, everything works great on LPG but after leaving it plugged in all afternoon the freezer was frozen and the fridge was getting cold, just much slower.
Normal???
โJun-13-2015 04:35 PM
dougrainer wrote:My bad, I read it as not working correctly on either.
You state it works correctly ON LP top and bottom? But on 120 it does NOT? Is this correct? If so, then it is NOT a bad cooling unit. Doug
โJun-13-2015 04:10 PM
โJun-13-2015 03:50 PM
โJun-13-2015 03:49 PM
โJun-13-2015 03:33 PM
โJun-13-2015 12:25 PM
โJun-13-2015 10:55 AM
Big Kahunna wrote:How old is the fridge?
Hello All,
I am having a problem with my Norcold fridge.
It works great on LPG and on shore power the freezer gets cold but not the fridge. I have power to the unit as evidenced by the freezer working.
Any ideas or suggestions would be appreciated.
โJun-13-2015 10:14 AM
