โMay-20-2024 07:08 PM
My Norcold model 611 (2007) does NOT get very cold when itโs on gas; but works fantastic when itโs plugged in to the Shoreline.
Any trouble shooting ideas that can help solve this problem???
Appreciate your responses and thank you๐
โMay-21-2024 01:59 AM
Check and clean the burner and orifice for any blockages, and ensure the gas pressure is adequate. If issues persist, consider having the gas regulator inspected or replaced.
โMay-22-2024 08:09 AM
โMay-23-2024 10:26 AM
I had a similar issue, found that spiders like putting their eggs in little "cotton balls" in the burner area. Cleaned those out and solved that problem by putting Chestnuts in the burner area. No more spiders.. In fact I have chestnuts in all my cupboards and passthrough. Maybe and "old wives tale" but it works.
โMay-23-2024 06:59 PM
You have an old unit, 15 years is a long time. check for any blockage up the flu and barring that, you're gonna have to replace the unit or get a cooling unit upgrade from JR Refrigeration in Indiana. Look him up on facebook/utube, I used his services on a previous motorhome, worked great. Good luck
โJun-01-2024 08:22 PM
I cleaned the burner before I went out this weekend with my RV and while using the gas, the freezer worked outstanding but the refrigerator is still not cooling down; any troubleshooting ideas that can help me out???
Thank you, and I appreciate any help!!!
โJun-01-2024 08:43 PM
Hello, you didnโt say how old the frig/coach is but if weโre talking 8-10 years or more then Iโm afraid your frig is dying of old age. You probably have a blockage in the system. I had the same issues many years ago. If youโre handy with tools you could order a new cooling unit and change it out ( YouTube it) or you might find a replacement on Craigโs list or Facebook. The change out is relatively easy, but buying used could be problematic. Good luck.
โMay-23-2024 10:39 AM
Thank you so much!!!
โJun-01-2024 08:21 PM
I cleaned my burner and I have an excellent flame and when I took my RV out for the weekend, my freezer worked outstanding but my refrigerator is not cooling off; any troubleshooting ideas that could help me out???
Thanks, and I appreciate any help!!!
โMay-22-2024 08:11 AM
Thank you so much for the troubleshooting ideas; I will definitely start with that and go from there๐๐
โJun-01-2024 08:20 PM
Took my RV out for the weekend and the freezer works outstanding, but the fridge does not work; any troubleshooting ideas for that???
Any info would be greatly appreciated and thank you!!!
โMay-21-2024 05:03 AM
Appreciate the response
I will follow up on this!
Thank u!!!
