Norcold N821 Shows A in Display
dano73
So that's whats on the fridge display, meaning lack of ac present. Theres no gas in trailer yet, so haven't tried the gas side although I can hear the ignitor clicking. Where do I start on ac side?
3 REPLIES 3
dano73
Took cover off circuit board, checked ac fuse, kinda getting a funky reading, pulled it, tested good lubed it put it back in. Pulled a bunch of connectors, just to shake em up, plugged it back in, working again, good to go.
dano73
Removed plug from fridge and plugged into extension cord directly. Same. Checking circuit board fuse next.
ScottG
Check the outlet it's plugged into for AC. If not there then check GFCI's in RV.
