โAug-22-2017 06:34 AM
โAug-23-2017 04:57 AM
โAug-22-2017 03:56 PM
โAug-22-2017 01:39 PM
myredracer wrote:
If an older unit and if multiple things are acting up, I'd start with looking for a bad connection(s) somewhere that have something in common - starting with the battery to frame & converter/charger to frame connections as these can be exposed to the elements and sometimes corroded. Maybe a loose connection in the ground bar behind the converter panel? Maybe check the voltage right at the battery when it is in charging mode after extending the landing gear and slides. Check positive connection at battery and at converter.
Installing a new battery means little as it's hard to screw up tightening up two connection in a dry/covered location and the battery should be working properly.
Intermittent electrical problems can be one of the hardest things to diagnose... ๐ If you were to take it back to the dealer, that likely won't help unless you could somehow demonstrate exactly what's been happening.
As a matter of course, I would check and tighten all 12 & 120 volt connections at the converter/panel and ground bar regardless. In our TT I found one wire completely loose at a breaker. Also have found a number if improperly done crimp connections with wires barely holding on and connections to frame and the mini-breakers (in A-frame) that were badly corroded.
โAug-22-2017 01:37 PM
donn0128 wrote:
Sounds suspiciously like a flood damaged RV. You might want to get serious and do a title search. Hope you bought it from a dealer and not a private party.
โAug-22-2017 01:04 PM
โAug-22-2017 11:32 AM
โAug-22-2017 11:16 AM
โAug-22-2017 08:55 AM
โAug-22-2017 07:48 AM
Nlambert182 wrote:
Could all of these issues be related, and could all of this be due to a short in the system somewhere, or would it be coincidence?
โAug-22-2017 07:00 AM
โAug-22-2017 06:36 AM
