โAug-24-2016 03:33 PM
โAug-27-2016 01:56 PM
โAug-27-2016 01:53 PM
MEXICOWANDERER wrote:
Hint:
If you have power at any of these wires but the power dies when the wires are connected together as Mr. Rainer, instructs, there is a problem with the feed wire to source of power.
โAug-27-2016 01:50 PM
dougrainer wrote:
There is no ground, or there is no positive. I never had to check. BUT, there will not be BOTH. You NEVER need Pos and Neg thru this type switch. You are only routing the wires together. That is why I stated, connect all at the same time and the Eyebrow may light up. IF NOT, then the rear board is bad. Doug
โAug-27-2016 01:48 PM
โAug-27-2016 01:37 PM
โAug-27-2016 12:01 PM
dougrainer wrote:
GOOD question. I think there are 6 wires to the switch. Maybe 5. I no longer have a schematic for that 30 year old refer. GOOD news is, you can connect all together as all it does is jump power to the board and the Hi humidity Heater strip. Find the HOT 12 volt wire. Then take each of the other wires one at a time and connect to the 12 volt wire. When you find the one that activates the eyebrow panel jut jump those 2 together. I would not worry bout trying to activate the Hi Humidity heat strip. Doug
โAug-26-2016 06:22 PM
KendallP wrote:
Doug,
How do I hotwire/bypass tthatswitch to test?
โAug-26-2016 03:41 PM
โAug-25-2016 06:31 PM
dougrainer wrote:
...IF the interior light comes ON in either position the switch is sending power to the board. IF the light comes ON, then odds are it is the board. Doug
โAug-25-2016 06:09 PM
KendallP wrote:
OK. That weird voltage situation appears to be solved. I had the 6300 series converter running with the bank unhooked. It was sending 7.5v to the board that way. Weird since that converter has a separate charging circuit, but we all know there are better converters.
Hooked it back up and I get about 13.5 at the board and about 13.1 at that humidity switch.
Doug,
Boards go too, right? What are the odds it's the humidity switch or something other than the board?
โAug-25-2016 05:40 PM
โAug-25-2016 03:39 PM
dougrainer wrote:KendallP wrote:
Hmmm. My unit doesn't have a switch on the board... nor does the board look like any of those. Looks like theboard I've seen for the 8310 and 838. My hhumidity switch is 3 position. Markings read from top to bottom...
Normal Operation
Storage (Light Off)
High Humidity
Refer will not power up unless in either Normal or High Humidity. The corrosion when you pull the switch is usually obvious. Doug
โAug-25-2016 02:51 PM
Normal Operation
Storage (Light Off)
High Humidity
โAug-25-2016 02:46 PM
