Older Xantrex Inverter transfer switch function- How to?
hertfordnc
I have a 10 yearold ThermoKing/ Ingersoll 1800 watt inverter (Actually made by Xantrex)
It's a modified sine wave but it works great.
I have no paperwork but I've read that it has transfer switch function.
There are knockouts on the front and a bus under the cover for input and output (120VAC not the DC input)
I can't find any info on how to wire it. I have some big AGM batteries and I'd like to make this into a UPS for freezer. If I can get the transfer switch function to work.
EDIT: It looks like and probably isTHIS ONE
Dave & Ellen Silva
Hertford, North Carolina
2002 Excursion
2007 Shamrock Hybrid
1972 Revcon
1976 GMC Birchaven (hot rod with plumbing)
Finding propane leaks with a match and towing in overdrive since 1987.
8 REPLIES 8
StirCrazy
Moderator
Moderator
personaly I wouldnt keep a modified sign wave inverter any more. motors use more power and run hotter on them, they can dammage electronics and so on. just be carefull what you use it for.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
dougrainer
The 120 input is behind one of those round knockouts. The OUTPUT is the front GFI receptacle. You remove the receptacle and wire the output to those receptacle wires. The original install kit came with a blank plate that replaced the receptacle. Doug
hertfordnc
deltabravo wrote:
It's the Xantrex Pro series: https://xantrex.com/products/inverters/pro-series/
Go near the bottom of the page for the specs, manuals, etc.
THanks. I think i got it figured out. I knew it was made by Xantrex but i never though to look for the Xantrex equivalent model.
I found my schematic.
Dave & Ellen Silva
2002 Excursion
1972 Revcon
deltabravo
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
hertfordnc
deltabravo wrote:
Can you post a photo of it?
I've never heard of that model inverter being made by Xantrex.
I posted the link to a current Amazon ad. I'm surprised they stall have it as i think it came out ten years ago. Looks LIKE THIS
Dave & Ellen Silva
2002 Excursion
1972 Revcon
deltabravo
hertfordnc
MrWizard wrote:
Do have the model number & year of mfg from info plate, to post here or maybe a pictures of the inverter outside and inside, some kind of info that members can compare to a xantrex unit in their rv,
thanks. edited.
Dave & Ellen Silva
2002 Excursion
1972 Revcon
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
