A friend asked me to help troubleshoot his RV generator.
It will not crank using the onboard start switch or the remote on the switch panel.
Using a meter I verified there is solid battery voltage at the starter solenoid. There is one small white wire on that lug that I assume powers the control & start circuits.
Using a meter I determined which terminal on the solenoid needs switched 12v and I jumped it and the genny cranked.
Anyone have a wiring diagram of the control circuit?
I'm hoping there's a fuse or an interlock somewhere I haven't discovered.
05 Durango Hemi
2010 Neo all-aluminum 7x20 CH
