โAug-28-2019 04:50 AM
James,Gail & Pancho
2005 georgie boy Pursuit
โAug-28-2019 12:09 PM
CloudDriver wrote:
I had the fuel pump on our Onan 4KYFA26100K fail a few years back. On this model the filter is screwed into the suction port on the pump as shown in the pic below. The rubber fuel line goes onto the barb fitting on the filter, which is accessible from the side of the generator base. The filter can be replaced without removing the pump using a deep socket, which is (I think) a 9/16". I used a piece of dowel to plug the fuel line to prevent a siphon.
Onan # for the filter
James,Gail & Pancho
โAug-28-2019 10:27 AM
โAug-28-2019 09:49 AM
โAug-28-2019 09:27 AM
โAug-28-2019 08:07 AM
โAug-28-2019 07:28 AM
ADAD437 wrote:
didn't check model, but not like yours.filter screws in on side and hard to get to, wondering if fuel will siphon from tank if line disconeticded from filter?
โAug-28-2019 07:12 AM
James,Gail & Pancho
โAug-28-2019 07:07 AM
maillemaker wrote:
Which model exactly?
Here is my 4BGE "Onan 4000"
You can see the fuel filter. You will want to unthread it carefully and thread on a new one and be careful not to cross-thread. It's easy to cross thread the metal tubing connector if it's not lined up exactly right.
Be sure to check for leaks after installing. Do not overtighten.
Steve
James,Gail & Pancho
โAug-28-2019 05:44 AM
โAug-28-2019 05:41 AM
