Onan 5500 Stops Running after 15 minutes
Racorman
I have a Class A gasser with the 5500 Onan generator. It has only 70 hours on it and it has run just fine until recently.
I start the generator from the inside control panel and it has no problem starting and running perfectly even under A/C load. Anywhere from 15 to 20 minutes the generator starts to stall and seconds later, it quits and cannot be started
I let it sit for an hour and I can start it up again..... 15 minutes, same stalling occurs.
Any thoughts on trouble shooting?
Thanks,
Racorman
AKA..... 56Nomad
2012 Itasca 30' Class A
2013 Jeep 2dr Wrangler
13 REPLIES 13
htwheelz67
remove the fuel cap and see if it does it, mine did the same thing, I repalced the fuel pump and same issue, then I removed the fuel cap and bingo it wasn't venting properly. I bought a new fuel cap and did the same thing, now if using the gen I loosten or remove the cap and it works fine (mostly in HOT weather) there must be a vent somewhere. If I tighten the fuel cap it dies in about 15 mins.
MEXICOWANDERER
RAcor Man?
Has your moniker anything to do with the fuel water separator filter manufacturer?
Chris_Bryant
Racorman wrote:
rk911 wrote:
any error code on the panel?
All it shows is off and on :R
The codes will be the indicator light flashing- shutting down, it should be flashing.
-- Chris Bryant
etrippe
I have the same problem and at this point I'm pretty sure it's the fuel pump. Onan gave me the part number and I searched amazon and saw the Airtex pump at half the price. But before I order the Airtex, I wanted to ask the question on this forum. Thanks so much for posting. Any installation issues?
thanks in advance
eric
Racorman
I took the motorhome to a Onan dealer and he suspected the fuel pump and recommend I replace it. He wanted $172 for it and a filter just for the parts.
I went ahead and found out that Airtex makes the fuel pumps for Onan and I ordered one on Amazon. Airtex E11015 Electric Fuel Pump for Onan Generator Set for $44
Here was one of the comments on Amazon:
This was an exact replacement for the original Onan/Cummins 149-2620 fuel pump. My original fuel pump developed the fairly common problem of causing the generator to stall after about 20 to 30 minutes then requiring a cool down before it would restart and run for another 20 to 30 minutes. I only have about 15 hours on the generator since replacing the pump, but so far, so good.
AKA..... 56Nomad
Racorman
AKA..... 56Nomad
Heisenberg
Mine was set for our elevation roughly 3200 feet. I went lower to about 1500 ft and my problem went away. I am sure it is a mechanical adjustment and it seats after heating up cutting the fuel off. Mine would run 30 to 45 minutes before sputtering and eventually dying.
2013 Winnebago Sightseer
2017 Colorado
Ltrip
Heisenberg, Can you be more specific on your altitude adjustment?
I live in Reno, Nevada, at 4500' elevation and usually go up or down from there. So I check this often.
If you are actually at 3000', for example. Do you set the gen to be 2000'? Or what?
I know it is difficult to be very accurate with the adjuster.
Thanks!
Larie Trippet Reno/Tahoe region
2018 Ford F250 Lariat Ultimate CC SB 4X4 diesel
2018 Arctic Fox 25Y
2019 BMW R1250RT
Heisenberg
I had the same problem with mine when brand new and the dealer could not fix it. I lost patience with them. On mine the fix that worked was to lower the altitude adjustment. Evidently it heats up and narrows a passage.
I had bought a new fuel pump and fuel filter. They are now spares.
2017 Colorado
Crazy_Ray
Need fuel pump
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
Ltrip
Mine is doing the same thing. I suspected the fuel pump. When the gen quit, I opened the carb drain and pressed the prime button. No fuel. Later when the gen would start, i shut it down before it quit on its own. I repeated the above and fuel came through.
So, I have a new fuel pump, fuel filter on order.
I anticipate that this will fix it. If not, on to the next possibility, which may require expert help.
A friend of mine had the exact same problem, and this solution solved his problem.
Good luck! Is your under warrantee?
2018 Arctic Fox 25Y
2019 BMW R1250RT
rk911
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
pfidahospud
Does it have a low oil automatic shutoff?
