My Onan 5500 wont start anymore. Been messing with it and figured out it is rich/not getting enough air. Have it narrowed down that if I slide the intake butterfly position lever so that it is open a bit more it starts. If the butterfly is open all the way it runs perfect. If it is open about 20% it is still good but seems like it is wanting a little more air (the sound is a bit different but it still runs perfectly smooth). When it does not start the butterfly is only being slightly cracked opened maybe 10%. It seems like it drifts down to this 10% when running and still runs but it wont allow it to start. I can't really figure out how the lever(?) grabs onto the pulley(?) to open the butterfly. I see when I go to start it that it moves the lever but never grabs onto the pulley to actually pull the butterfly open yet nothing seems obviously broke or missing. If I force it open by rotating the pulley it stays open as again the pulley just slides without grabbing the lever. Hopefully that makes some sense. Here are some pics.
The black somewhat L-shaped piece is what I am calling the lever and what I am calling the pulley is the arc shaped piece it connects to. I don't understand how it ever grabs the pulley when it trys to move it as there is just two loose washer like rings on both sides:
Butterfly 100% open runs great/sounds very strong:
Butterfly 25% open ... still runs great and sounds strong but close it a bit more and sounds muffled yet still runs but wont start again after shutting generator off:
Its not the filter as putting the filter back on does absolutely nothing. its also not the altitude setting which also seems to have no effect. When it wont start the light flashes three times so I don't know if this is telling me anything specific.
What might be wrong? Is something missing or broke on the lever?
- '16 Fuzion Chrome 420 (Previous: Weekend Warrior '05 LE3105 and '06 CL40005)
- '15 RAM 3500 SRW 4x4 Aisin Crew (Previous:'05 Dodge 2500)
- '17 Maverick X3 RS (Previous: '08 RZR 800, '13 XP 900, RC51 powered RZR, Hayabusa powered RZR)
