Onan BGM5500 Oil Leak Fixed by Me, Thanks To These Forums!
EastTexasFoster
On the way to Colorado in our '98 Southwind 35s back in June, we noticed the generator surging, then saw some smoke coming from underneath. After pulling off of the road, found that oil was all over the generator and compartment, and dripping from underneath. It was down over 1 quart.
We finished the trip without using it. Back home in Texas, I bought a service manual, and the troubleshooting guide suggested what I thought might be the culprit; the crankcase breather was probably clogged.
Without removing the genset, I managed to get the top of the casing off. It was a pain taking out all of those bolts around the back and left side, I think Onan obviously did that to discourage people like me. Too bad, I did it anyhow.
OK, so I checked the breather, it seemed to be fine. I didn't bother removing it, there was pretty good pressure coming out of the top of it. I also checked the exhaust for obstructions, none found.
I then cranked it up, and saw oil popping up out of an open hole on top left (toward the rear of the motorhome)of the engine assembly, nearest the muffler compartment, and realized I had stumbled across the problem.
Then, I googled it, and found a couple of threads here on RV Net where people had encountered this issue, and how they had repaired it.
I checked the hole, it was .750" (3/4") at the uppermost part, about 1/4" deep.
I found that Onan does make a replacement plug, part # 517-0293, but nobody around here stocks it.
At least one of the other folks reporting this had used a welch plug, so I located one (funny, as common as welch plugs are, very few parts stores knew what I was talking about, and only one had the 3/4" diameter). I've now had two good experiences with Bumper2Bumper.
I cleaned the open governor shaft hole with acetone, applied red Loctite on the diameter of the welch plug (if you ever install one, the dome top goes up, don't flip it where it is like a bowl).
after I centered the welch plug in the top of the hole, I placed a socket on top of it, then firmly tapped it down into the hole with a hand-held sledge hammer. It tried to cock to one side, but I persuaded it finally to go down evenly.
I then mixed some JB Weld and ran a bead around the sides of the plug.
Later in the afternoon, I fired it up. We now have our generator back, running and sounding like it did before. Kudos to those who had previously posted their experiences, it helped me to do it myself!
5 REPLIES 5
EastTexasFoster
Not to create hostility, but as a retired machinist and mechanic who sometimes used both types of plugs, I have to say there is somewhat of a distinct difference. The welch plug is like a flat coin that is pressed in the center to become slightly rounded, and when installing, the outer diameter edge is increased slightly by pressure applied on the center of the top of the convex, rounded surface. While it may look similar from the top of the sometimes-rounded surface, the traditional freeze plug has a side surface forming the working outer diameter, that is at approximately a 90 degree angle from the rounded surface. It looks as if you attached a bushing to the concave bottom of a welch plug; some of the old freeze plugs don't even have the 'domed' shape, but are flat across.
As we know, they both have a similar function, but there are places where a freeze plug would not work so well, such as when the hole to be plugged has a very shallow shoulder. I chose to go with the welch plug.
I found it interesting that most of the auto parts clerks and industrial supply people I spoke with had no idea what either one is. I guess my age is showing by way of my technology. LOL
wirenutz
I call them freeze plugs
2007 All American Sport Toy Hauler 38 foot, 14,400 LBS dry weight
1999 Four Door Freightliner,new 6 Speed Auto, new Cat Motor, 12,600 LBS, rear air dump, lowers rear by 3", air activated rear locker, air ride seats, air ride cab, air ride suspension
path1
Might be of reference to others at a later date?
http://www.smokstak.com/forum/showthread.php?t=117184
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23536149/print/true.cfm
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
j-d
AMEN to what Rob said! Good on YOU!
robatthelake
Isn't it great when We have such a wonderful resource like this forum! I have learned a Wealth of great information here over the years!
Well done on diagnosing the problem and repairing the Genset on Your Own!
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
