Onan microlite 4000
tarnold
Surges, smells running rich. Oil ok, filter clean. TRC meter shows 55-57 hrz, 160-170 volts, red light on. Plenty of fuel in tank. No rats nests, all linkages seem to be working freely.
What to check next?
5 REPLIES 5
chinook507
Check your hose from the crankcase breather to see if there are any cracks in the hose. Like someone else said be sure to run it at least once a month with a load. That is an important step to not miss. Also I always use Stabil in my fuel.
2001 Excursion V10
2013 Keystone Cougar
1997 Kawasaki 1100STX Jet Ski
1991 Kawasaki Bayou 300 4X4
1989 Kawasaki Bayou 220
1989 Kawasaki Bayou 220 2X4
tarnold
Well, donโ€™t know what I did but it runs fine now. Just reset all plugs, might have been some corrosion somewhere?
MDKMDK
https://www.cummins.com/sales-and-service
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
tarnold
This unit get run at least once per month with a load? Either heat pump or a/c on. Just don't think it would be good throwing all that voltage in to the system?
winnietrey
When mine has done that, it is after an extended period of none use. I have found if I let run for an hour or so it will straighten itself out.
