โJul-07-2017 08:48 AM
โNov-21-2024 08:34 AM
4000 onan.Will run great while parked. Driving it cuts off about 20 minutes into trip. Itโs 42 degrees, so I donโt think itโs heat. However I have replaced carb, fuel pump, air filter, fuel lines are wrapped in heat shield, fuel pump is wrapped in heat shield, inline fuel pump was installed by fuel tank.I took outer rv door, not generator cover off.That didnโt help. Any is help appreciated.
โNov-21-2024 10:01 AM
Hi and welcome. You are posting a question as a response in a thread that's 7 years old. You may find it beneficial to ask your question in a new post as it's likely to get more answers than being buried in a very old thread.
That said, have you checked your wiring? A loose ground could cause your genset to stop running - not moving keeps it connected while driving it may jar it loose. Also, is it throwing a code? Gensets require constant power from the batteries to keep the fuel solenoid open.
โSep-18-2021 03:27 PM
โSep-18-2021 05:05 AM
โSep-17-2021 04:00 PM
โJul-08-2017 05:41 PM
โJul-08-2017 05:31 PM
โJul-08-2017 04:26 PM
โJul-08-2017 04:08 PM
โJul-08-2017 03:51 PM
โJul-08-2017 06:16 AM
โJul-07-2017 06:42 PM
โJul-07-2017 04:11 PM
Bud
USAF Retired
Pace Arrow
โJul-07-2017 03:47 PM
