one leveling jack retracts
ontheroadbob
I have a 13 Bounder with Power Level auto level system
After about a day the right rear jack retracts just off the ground. There is no external leak.Is the pressure held at the power head unit or at the jack and is the check valve replaceable?
1 REPLY 1
dougrainer
Yes, The pressure is held at the power unit and the solenoid is replaceable. But, manually open and close it first. Sometimes debris gets in the needle and causes seepage internally. Doug
