Only kitchen faucet won't flow.
CptSydor
I've searched, but can't seem to find this exact situation, everything seems more global.
After de-winterizing my trailer a few weeks back, I was flushing the lines and all the faucets (kitchen, bathroom, shower and toilet), both hot and cold were flowing just fine.
I got sidetracked and a week later I went back and directed water back into the hot water heater.
From my recollection, it seems that after I filled the hot water heater, my kitchen faucet started spurting, and now does nothing. Both hot and cold water. Not sure if those two things are related or not.
I was just back out in my trailer. I hooked up city water, the kitchen faucet dribbled a little water, then dead again (my city water feeds almost directly into my kitchen faucet for cold). No apparent leaks anywhere.
My faucet has both a hot and cold on/off.
All the other faucets/toilet, both hot and cold are working from both city and the fresh water tank.
Any ideas?
8 REPLIES 8
wa8yxm
I see you solved your problem but I will tell you of another.. This applies only to those kitchen faucets where the head pulls out and doubles as a sprayer.
There is a check valve in the head where the hose connects.. It too clogs up.
2BNOT2B
Also cleaning your water heater will help remove sediment. I do mine once a year, but I do not winterize.
03, Fleetwood Expedition, 39Z
300HP Cummins, 6 Speed Allison
2013, Jeep Wrangler Sport
mobeewan
Probably stirred up sediment in the water heater when it filled up which in turn blocked up the aerator.
Kit_Carson
Check the filter on the pump also.
KIT CARSON
GOOD SAM LIFE MEMBER
USAF VETERAN
ARS: KE5VLE
NORTHWEST LOUISIANA
RJsfishin
Would you think that when you filled the wH, that it washed the sediment off the bottom and right into the faucet ?
Does that say its been a while since you drained the WH ?
Rich
ppine
Often there are little screens in the water lines connected to the faucet. Take it off, clean it and check the screens.
CptSydor
Man I feel silly.
Yes that was it. 5 second fix.
donn0128
Aerator plugged.
