I have been running on solar/battery and inverter for about two weeks now with no issues. Last night i plug into 30 amp outlet on park pedestal and the tv would not run. I use the plug tester to check status. The plug tester in trailer receptacles showed open neutral and the the volt meter showed 60-88 volts. (I dislike plugging into park power)
Plug tester on the 20 amp GFCI outlet on park pedestal showed good so i plugged into it using adapter on rv cord. All is good until i turn on 20 amp breaker in the RV electrical panel box for converter and then after 5 minutes i get open neutral and 60-80 volts.
Wake up in the morning and remove electrical box and check all connections to include the connections on the transfer switch and all grounding bars. All connections are good to include continuity of RV cord. The inverter is still producing good electricity.
RV is 30 amp service as was the park pedestal. Pedestal had 50/30/20 amp outlets on it. I did plug the 50 to 30 amp adapter into 50 amp outlet but still was open neutral and 88-91 volts.
The trailer electricity was fine about two weeks ago when i was connected to 20 amp service at brother's house. There was no issues.
What should i check next? The trailer is back in storage so i will have to go get it out to do more checking. I am hoping it was pedestal issue and not my rolling condo. Any help is appreciated. Thanks,
Greg
2004 KZ Durango 275RK,
2006 Dodge RAM 3500 (Big Hips edition)
