โJul-30-2016 02:12 PM
โAug-04-2016 03:30 PM
CJW8 wrote:
You haven't really stated the problem yet.
Gen wont run?
Gen runs but quits?
What?
Recently on two different RV's where Gen would run but quit. Both belong so sons in laws. First Travel trailer toy hauler. The fuel tank was about 25 feet from the generator and the fuel pump is located at the generator. A second fuel pump was added near the fuel tank. Second is a class C MH. Same issue. Gen would quit if the motorhome was going up hill or of it was parked slightly up hill. In this case, the installed fuel pump was relocated to near the tank. Both now run flawlessly. I believe on the MH, it was actually vapor locking because if the long suction line to the tank, high heat and 3 high points in the fuel line.
โAug-04-2016 10:15 AM
โAug-04-2016 12:14 AM
โJul-31-2016 10:57 AM
โJul-31-2016 05:21 AM
โJul-30-2016 04:33 PM
path1 wrote:
Op here...OK thanks folks. I was under impression (probably wrong?) that the fuel pump would pump so much gas in 30 sec or 1 min. A trouble shooting test to see if fuel pump is my problem.
โJul-30-2016 04:19 PM
โJul-30-2016 03:27 PM
โJul-30-2016 03:13 PM
