LipschitzWrath's avatar
Aug 08, 2018
Parasitic Draw on RV?
I am getting ready to add a small solar system to the top of my 5er to keep the batteries topped off when we leave the camper at the lake for extended periods. My wife and I generally pull the camper out on a weekend and then leave it there for weeks at a time. We pull it to a nearby dump station when we need to dump or add water. We cycle LP tanks to keep the fridge cold.
Last weekend, we returned to our camper after two weeks of leaving it unattended. The batteries were COMPLETELY dead. This seemed odd to me. I mean, assuming we turn everything off before we leave, the only draws are the LP/CO detectors and the little current draw to run the fridge in LP mode, right?
So how much juice do these items consume?
After doing some internet research, I found one site where some dude claimed these items add up to approximately 37Ah in a 24 hour period. I've seen other sites say the fridge pulls 17-20Ah per day by itself in LP mode. The fridge is a Dometic fridge/freezer, I don't have the model number handy but it's from 2004.
Do these numbers sound right?
I have 210Ah of AGM batteries installed. If these numbers are close, then that would certainly explain the dead batteries.
This brings me to the solar panel install. I guess a secondary question would be, do you guys think a single 100W panel would be sufficient for the sole purpose of keeping the batteries topped off when the camper is unattended?
I don't mind occasionally running the generator(s) when we are actually out there using the camper.
Thanks in advance!
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
