Park brake
tspeckin
I'm posting this for a friend in hopes of helping him out. I apologize up front if I don't know exactly what I'm talking about. He bought a used class c and used it this past winter on a trip to Fla. No problems. Last week he went to leave on vacation and the drive train was locked up. Apparently there is a brake inside the drive shaft that engages when the vehicle is put in park. It appears that there are electric switches that engage a hydraulic pump which applies the brakes. Anyway, the brake will not disengage. Any body out there know what I'm trying to explain and may know a remedy?
2007 Keystone Laredo 29GR
8 REPLIES 8
tspeckin
Thanks for all of your help. I forwarded this thread to him. Looks like you all got him on the right track. All of the mechanics that he contacted acted as though he was speaking a foreign language with this system.
wolfe10
That is Roger Haag.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
NORM_WADDELL
MY last address on OLDUSEDBEAR (Roger Hopkins) is
OLDUSEDBEAR@OEMYS-PERFORMANCE.COM
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
wolfe10
With that chassis, OLDUSEDBEAR is your "go to guy".
Brett Wolfe
Ex: 1997 Safari 35'
tspeckin
My mistake. It is a class A, 1999 Damon Challenger in a GM gas chassis.
wolfe10
Please post specifics: What chassis-- Ford or GM? What model year?
Brett Wolfe
Ex: 1997 Safari 35'
sum1
If this a Chevy chassis, Norm is probably right. I'm surprised to hear that it's a Class C instead of a Class A, however. One way to disengage it TEMPORARILY without things going BOING is to tighten the Locknut on the Actuator Shaft against the housing, then continue to turn it until it pulls the Shaft out enough to disengage the Brake. You might need to use a fender shim of the right size as a washer if the hole is too big for the Locknut to seat against it. As Norm said, take all precautions so the MH doesn't roll over you.
Above all, get in touch with Oldusedbear before you let anyone touch it, as Norm said.
Please keep us posted.
NORM_WADDELL
You are probably referring to a brake which clamps
around the drive shaft when the selector is placed
in 'PARK'. This is called 'Auto Park'. It was
used because the motorhomes were to too heavy for the
normal park pawl (gear) to hold them. This system is
commonly controlled by the ROTTEN GREEN SWITCH. When
it fails, the clamp around the shaft is locked in place.
On this website, find OLDUSEDBEAR, and he is the EXPERT on
this system.....he will help resolve the problem, which
often requires replacing the switch. On my motorhome
this system is front left, under the 'hood', and
contains a plastic tank (small) for the fluid and
a pump, and the famous switch. (It is possible that
the tank is out of hydraulic fluid, so that the system
cannot release the clamp/brake). A mechanic can go under
the motorhome and remove the clamp/brake, but the driver
will have NO PARK FUNCTION.......the R V will roll away.
Blocks have to be placed under the tires to stop this
danger. (Good luck !)
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
