Patio awning will not extend
Iamhopeful
I have no power going to the rocker switch. Everything checks out
6 REPLIES 6
Bull_Rider
Yes. the red one.
If you receive help from other members, don't forget to update your topic with the results.
dougrainer
If everything checks out, it should work:B Obviously, everything does NOT check out as the awning does not work. As the 2nd poster stated, you MUST supply info for someone to help you. Doug
Old-Biscuit
Just guessing.........
Blown DC fuse.
But not telling until you check back with real info which 'I am hopeful' you will provide
beemerphile1
Welcome to the forum. You have made two posts now and given zero information. You also have no information in your profile.
I think you will need to make a few more keystrokes and provide us non-mindreaders with some more info.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
1492
Moderator
Moderator
Moved from Forum Technical Support
SCVJeff
-What make RV ?
-What Model ?
-What Year ?
-What make Awning ?
-What Model ?
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
