โMay-25-2015 08:25 PM
The PD9245C-14.8 is a 45-amp power converter/charger designed to provide reliable filtered DC power for batteries that require a higher boost/bulk voltage such as Trojan and others.
โMar-23-2022 03:42 AM
โMar-22-2022 06:56 PM
โMar-13-2022 06:06 PM
โMar-10-2022 01:59 PM
โMar-09-2022 10:14 PM
3 tons wrote:
I may be forced to consult the Oracle at Delphiโฆ
3 tons
โMar-09-2022 03:55 PM
MEXICOWANDERER wrote:
Send the manufacturers of these abominations, a giant stereo with 18" speakers and a thousand watt amplifier...
Include a CD of the 1070's recording by the Chambers Brothers
TIME!
Let the sound of the recording resonate through the mahogany lined offices.
TIME !
Rattle the windows
TIME!
Drop pictures from the walls
TIME!
Bake a cake for 45 minutes at 350F and it's finished
Therefore
Bake a cake at 3,000F for thirty seconds, and that otter do 'er...right? Same thing.
A converter is a converter. A charger is not a converter so if it waddles, quacks, and has feathers, it isn't a crocodile. Build a switch-over circuit in the dingle-dongle and select Converter OR Charger. The charger is programmable to meet the demands of a battery charge, not the needs of a Power Post Princess suckling at a spider-webbed cord hookup. When the charge is finished the unit DEFAULTS back to converter mode. How hard can it be?
โMar-09-2022 03:29 PM
KJINTF wrote:
It's a simple modification to increase boost voltage from 14.4 to 14.8 or almost anything you desire. Pin #5 of the micro controller is connected to a 32.4KOhm resister - drop the value by several hundred Ohms and the Boost increases - Simply solder a 60KOhm across the resister in question.
โDec-10-2015 10:53 AM
โDec-10-2015 10:33 AM
โDec-10-2015 10:15 AM
โDec-10-2015 05:33 AM
lbzya wrote:
The only thing changed is what PD calls a boost mode to 14.8v
โDec-09-2015 08:50 PM
โDec-09-2015 11:06 AM
lbzya wrote:
Ask and you shall recieve. Just talked with Randy and he stocks a PD9260 that has the 14.8 bulk charge. Just have to place the order now.
โDec-09-2015 10:10 AM
