plumbing
RVMike
I have a 2015 Itasca 27N with constant leaks. After driving 2-300 miles the fittings come loose at the faucets. I tighten them up and all is good until I drive another 2-300 miles, Is tape or thread dope suppose to be on these plastic fittings?
6 REPLIES 6
westend
I plumbed my trailer from the tank to all the faucets. I used PEX pipe, brass full flow valves before the supply lines, braided stainless supply lines to everything. I rebuilt the 44 year old faucets with new washers. I've found that plumbing is one spot where saving money is not efficient. If I have a leak and have to come back to it later, any money saved is blown away.
'03 F-250 4x4 CC
time2roll
Replace the fitting that you just tightened. Probably just get a new faucet while you have the fittings loose. Nothing very special just get what you need at Lowe's etc.
stickdog
Don't connect them direct I had problems with mine till I replaced the direct connections with the braided faucet hoses.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
imgoin4it
Usually faucets in RV's are made by pheonix. First time they leak replace them with one from a hard ware store. I usually replace them with moen. Look the same but last forever.
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
RVMike
I replaced all my faucets in my older Fleetwood and never had a problem, the Winnebago leaked from day one and the dealer claimed to have tightened them also.
donn0128
How tight are you making them? Seems to me there is a reason? Either your not getting them tight enough or something???
