Potential engine overheating
JayNewbieRV
I have a 2007 Winnebago view 23 and the temperature gauge gets pretty close to the red when going up hills.   I just bought this and itโ€™s not even the middle of the summer yet, any recommendations to fix this problem; To need a new radiator, flush, or???
Appreciate any ideas
thank you
2 ACCEPTED SOLUTIONS
Yes by all means if the engine is close to red the electric fan should be howling ferociously.
Check the coolant level.  These heating issues can be a multitude of things but start with getting the fan running.
View solution in original post
Shows how old I am.  I don't think anything has had a fan clutch in decades. Maybe an electric heat sensor for the fan has failed? Of course he should check the coolant level and for material blocking radiator first, after that, taking it to a good shop with an analyzer should tell him if the fans heat sensor has failed or if the fan motor itself has died.
6 REPLIES 6
JDsdogs
Nomad II
Nomad II
If you could tell us what chassis and engine you are running, it would help.
Depending on what engine (make, model and displacement), it may have a clutch on the fan that is going bad.  I have had this happen.
The 2007 Winnebago View 23J has a Mercedes-Benz diesel engine with a Dodge sprinter chassis The engine is a 2.7 liter, five-cylinder turbo-diesel, and the transmission is a five-speed automatic.
appreciate your response thank you
And whatever help you can send my way.
note:  Should the fan actually run if it overheats and I should hear it and see it run???
Your solution is the best piece of information I have received and I really appreciate the time you took to send me an email and I have made an appointment with the radiator shop. Havenโ€™t looked at; Thank you so much and I hope you have an awesome day๐Ÿ˜Š
Thank you ๐Ÿ™
