โApr-12-2023 01:56 PM
โApr-26-2023 08:33 AM
Chum lee wrote:dougrainer wrote:RLS7201 wrote:
Correct, the gear does not come individually. It comes with the 3 cushions.
Gear
Richard
Thanks. That is a alternate source. Not Kwikee(LCI). Was not available a few years ago. For $16, safe bet to try. Doug
Yes. When I repaired my 1999 Series 32 steps that had similar issues (with an upgrade kit) in 2015, that gear was not available, and, believe me, I looked. It wouldn't have helped me anyway because the large die cast metal reduction gear inside the main gearbox is what exploded on mine. I do mean exploded. It was in five pieces inside the gearbox and the steps swung freely in the air. They would not extend or retract fully.
IMO, if your broken Kwikee stairs are +15 years old, replacing one gear in the drive train makes as much sense as replacing 1 broken link in an old worn out bike chain.
Chum lee
โApr-26-2023 08:21 AM
Gear
Richard
โApr-26-2023 05:21 AM
โApr-25-2023 01:06 PM
โApr-24-2023 08:52 AM
Gear
Richard
โApr-24-2023 08:37 AM
โApr-24-2023 07:44 AM
โApr-24-2023 07:39 AM
CWilson wrote:
The entire situation can be summed up in one word.
LIPPERT!
Good luck.
โApr-23-2023 09:25 PM
โApr-13-2023 02:26 PM
โApr-13-2023 08:50 AM
MrWizard wrote:
I think he means look to verify broken or not,
Motors are available
Gear boxes are available
Replacing old motor with a new replacement version can also mean modifying the wiring, the last motor i replaced did not have the same connections as the one i removed, replacing the controller usually requires replacing the door sensor switch, because the controller circuit has changed to sense a different switch connection,
One is a switch that closes AKA when the magnet is near, one is switch that opens when the magnet is near, I'm not sure which one is the old design and new design,
I think closed when magenta is near AKA normally open switch is the old style, but i can't swear to that,
Anyway the controller is not the OP's problem
โApr-13-2023 01:33 AM
โApr-12-2023 11:39 PM
โApr-12-2023 06:46 PM
pconroy328 wrote:
Thank you MrWiz... Everything is well lubed, no binding. Motor grinds with at the same spot with no load, with steps disconnected.
It's like it doesn't know it's at the limit and keeps pulling.
I guess yanking the motor and looking for some broken teeth is next.
