โMar-26-2015 01:35 PM
โApr-06-2015 06:04 PM
SaltiDawg wrote:RinconVTR wrote:SaltiDawg wrote:
It is my experience that a full 20# propane bottle will produce the same amount of work as 4-5 gallons of gasoline.
And this is impossible FYI. You're talking 1:1 the same energy content LP to Gasoline? Not possible...
Actually you are demonstrating a lack of understanding of Thermal Efficiency considering different fuels and how it relates to fuel efficiency in a small four-cycle engine. You cited a home heating fuel comparison page and compared the available work or heat energy taken from that page for the two fuels on a per gallon basis.
In the case of home heating, the thermal efficiency of an older oil (diesel) is about 80%. On a new condensing furnace using Natural Gas or Liquid Propane thermal efficiencies approaching 95% can be attained.
In a small four-stoke engine you have assumed that the efficiency of that engine using gasoline is the same as using LP. Than telling me that my assertion about in my experience that a 20# bottle is about the same as 4-5 gallons of gasoline is impossible. Let me absolutely assure you that in my experience and that of many, many other posters over in the US Carb forums that approximation is right on.
So, while gasoline does have a higher amount of available energy when compared to LP, the increased engine efficiency tends to mitigate that difference.
โApr-03-2015 05:39 PM
โApr-03-2015 04:37 PM
โApr-03-2015 02:10 PM
smkettner wrote:
Tank has an OPD valve to prevent over fill. Tank is already designed to stop at 80%. No need to short fill to 80% of 80%.
100% filled to capacity (40 lbs.) is 80%.
โApr-03-2015 01:30 PM
โApr-02-2015 05:35 PM
smkettner wrote:
I am looking for an explanation on how all these posts think you can deliberately fill to 100% gross volume vs. 100% rated capacity.
โApr-01-2015 09:02 AM
dougrainer wrote:RinconVTR wrote:wnjj wrote:
The reason for not filling the garden sprayer to 100% is a functionality one. The reason for not filling the LP to 100% is a safety one. They operate on completely different principles.
No sir. They are the actually pretty similar in principle.
Go ahead and fill an LP tank 100%, it will not be functional for long due to lack of pressure. Liquid...it doesn't compress, remember? And LP will not remain a liquid, unless its under pressure. It requires a volume of "air"...under high pressure...for the tank to function.
SO that 20% is not just there for thermal expansion (safety), its there for pressurization as well. Just like the garden sprayer.
And that 20% is not a magic number, it can be much lower for these tanks to operate, don't get me wrong. The expansion rate of LP is very high. The US has very strict, protective rules, as we all know.
THERE IS NO AIR IN A LP TANK/CYLINDER. There is only LP vapor that is produced from the LP liquid in the tank. Soooooo, for a 100% full liquid tank, there is NO ROOM for the Liquid to vaporize. As I stated, 100% liquid will cause Liquid to flow OUT when the tank valve is opened and that will destroy the LP regulator. Doug
โMar-30-2015 07:51 AM
red31 wrote:The safety valve is there for malfunction.smkettner wrote:
First of all anyone that talks about overfilling a propane bottle to 100% of gross volume needs to explain how they are getting past the OPD valve that limits the fill to 100% of rated volume.
The OPD is not functioning correctly. If the OPD does not shut off at below 80% (40# in OPs case), no one will know it is not working. It is not the primary device used to fill.
If the filler stops filling cuz the scale tips, the OPD did not engage.
If the filler stops filling cuz 'liquid' is coming out the fixed max liquid gauge, the OPD did not engage.
Since 80% of container volume is based on 40F, any temp above 40F, the OPD should stop filling since the volume of liquid is larger. The dip tube length (DT) is based on 40F/80%, specific gravity of .504-.510 .
4-4.3.3 Where used, the volumetric method shall be in accordance
with the following:
(a) If a fixed maximum liquid level gauge or a variable liquid level
gauge without liquid volume temperature correction
is used, the liquid level indicated by these gauges
shall be computed based on the maximum permitted
filling limit when the liquid is at 40ยฐF (4ยฐC) for aboveground
containers or at 50ยฐF (10ยฐC) for underground
containers.
โMar-30-2015 05:45 AM
wnjj wrote:
Also consider that I only jumped into this mess when it was claimed that a 100% full cylinder wouldn't allow anything to flow out of it.
โMar-30-2015 05:38 AM
โMar-29-2015 02:53 PM
dougrainer wrote:wnjj wrote:
If you have a full container of liquid under pressure, the second you open the valve there is an increase in volume (the hose) which will drop the pressure rapidly. The first liquid to enter the hose will immediately boil off to gas. Now if the cylinder was at such a high pressure that adding the hose volume doesn't drop it below vapor pressure then liquid could flow to the regulator.
NOT TRUE. PERIOD. Doug (35 years as an RV Tech and 35 years Licensed by the Texas Railroad Commission, which trains and license LP service and fillers). Liquid also will into the piping even at 80% fill by the sloshing while driving. NOT so much a problem on DOT tanks but a common problem on Motorhome ASME tanks. Since the standard of auto cut off valves years ago this type problem has been minimized.
โMar-29-2015 10:41 AM
red31 wrote:beemerphile1 wrote:
I don't understand all the confusion on this subject which gets rehashed regularly.
An LPG cylinder is filled to 80% of WC (water capacity). That means a 40# rated cylinder holds, guess what, 40# of LPG when filled to 80% of WC.
cuz folks keep posting incorrect info.
42% of WC is not the same as 80% WC. WC is in lbs not vol.
80% WC does not account for the sg difference. 42% does.
http://www.mantank.com/products/dotproducts/5-420steel.htm
http://www.nfpa.org/Assets/files/AboutTheCodes/58/58-98-PDF.pdf
โMar-29-2015 09:34 AM
RJsfishin wrote:There's no such thing as a stupid answer. :W
its not hard to tell those that don't have the foggiest idea, but insist on posting anyway,.
โMar-29-2015 09:23 AM
