Question on changing leaf springs on 5'er
phemens
Hi,
I will be changing out the flat leaf springs on my 2012 5th wheel on all 4 wheels. Was wondering if there is any advantage to doing it by axle (i.e. both wheels on one axle, then both on other) vs. just doing one side at a time (both wheels on one side, then the other). 2nd way would reduce some of the setup time I guess.
Thanks in advance!
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
11 REPLIES 11
Huntindog
time2roll wrote:
I put my entire trailer up on jack stands and did one side at a time. Seemed easier since I was replacing the equalizers etc that connect to both axles. A day to lift, day for each side then down made for three weekends.
Mine was out of alignment due to sagging springs so once replaced all was good.
Sagging leaf springs do not change the so called alignment on a trailer..... Unless one is sagging more than the others.
Huntindog
100% boondocking
2 bathrooms, no waiting
17.5LRH commercial tires
Huntindog
Huntindog
100% boondocking
2oldman
Is something broken, or preventative maintenance? My leafs are still good after 18 years - or at least they look and work fine! Youtube got anything?
phemens
No worries on the shackles, I replaced them with heavy duty Moryde ones with the wet bolts 2 seasons ago. I added an extra leaf to the springs when ordering and will replace all the hardware on the springs.
Veebyes
Nice to be able to lift up the whole thing one time but if that is not practical one side at a time. Leave it on the truck if doing one side at a time.
As suggested, while up there might as well replace & upgrade shackles etc. as well. Builders put on minimum spec hardware. I upped my spring pack from 6 to 7 leaf. No worries about breakage now.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
time2roll
phemens
Good catch Don, I will!
pianotuna
Nomad III
Nomad III
Make sure to have a wheel alignment done after the springs have been renewed. DAMHIK
Regards, Don
Cummins12V98
Use a TrailerAid Plus and do one at a time.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
phemens
SDcampowneroperator wrote:
Both on one axle. You will need to lower and raise it to change out the spring, then align it to the centering bolt.
While you are at it its a good time to replace shackles, bolts amd bushings.
Shackles were all done 2 seasons ago (changed to the lubed kind)
I was under the impression I could lower 1 side of the axle at a time instead of both sides?
SDcampowneroper
