phemens's avatar
phemens
Question on transfer switch with inverter and generator
We mostly dry camp, rarely on shore power except at home. I installed 1000w of solar and have 630 AH of battery (3x Rolls 12 @ 210 AH each, big beasts). Inverter is a 2000w Kisae PSW, and I run a cord to the 30A shore power plug to run it. Usually this meets our needs, but want to do more camping in spots where solar will be less reliable. For now, when we need generator (2000w Yamaha inverter), I run outside, unplug the inverter cable and run the shore power line to the Yamaha. I need to turn on the converter/charger to charge the batteries. Once done, reverse the whole operation (I usually forget to turn off the converter until I hear the fan kick in on the Kisae, reminding me that I've created an inefficient loop). Kisae has a remote switch.
Getting older and lazier, there must be an easier way, right? Transfer switch I guess. I'm not an electrical wizard, but I'm handy and can do most things myself with a little guidance. However I'm a little fuzzy on the wiring diagram for all this and could use that guidance.
Ideally, I want a situation where when on shore power, converter is charging batteries and everything is powered up. On generator same thing. On inverter would prefer to not have to remember to turn on/off the converter. I assume I don't need to worry about the solar controllers (one 30A, one 50A, both wired to battery bank.
All the equipment is relatively new, so ditching anything isn't in the cards (may eventually move to a bigger generator to power AC, but not now).
Any help is appreciated on the wiring and suggestions for switch.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
