Greetings.
I have a 2011 Carri Lite 37' fifth wheel with double walled black/grey tanks heated by a 4" duct from a 40,000 btu LP furnace. I'm outfitting the trailer for 15-25 degree winters in the mid and north west. While in parks at a 50 amp pedestal, I want to cut back on running LP to heat the tanks, especially since the T-stat is inside and the tanks are outside. I like to use electric heat a lot while in parks.
I've reviewed UltraHeat's webside and have a couple questions for those who use these tank heating systems.
1. Should I get the one that runs DC and AC? If it's 20 out the DC would seem to make sense traveling. I wouldn't use it while dry camping, because it looks like it would kill the batts fast.
2. Does this system work with double walled tanks? I'd be sticking the pad to the outside cover, not the tank.
3. I'd leave the 4" LP heat duct to the tanks in place and have that LP heat alternative available if I loose electrical power in the night. I'd set the T-stat on say 50, while using ceramic space heaters and my fireplace inside. I have a heat pump in the living room, but it would be too cold for that. Does my thinking make sense or is there a better strategy to coordinate LP, electrical and UltraHeat systems?
4. Does anyone know if he DC heater kicks on if the electrical power goes out? I ask because this would be good to keep the pipe pads and elbows warm. As long as the power didn't stay off long, I guess the batts could hold out.
5. I'd buy this today and install it soon for next winter. Any thoughts on where the on/off switch should be located would be great. I assume it goes in the coach maybe on the bulkhead wall adjacent to the furnace.
6. I'd get the pipe/elbow pieces. I already let one of my electric valves freeze, so want to avoid that. I wonder if buying a pipe or elbow piece and putting that on the water pump makes sense. My pump is above the underbelly insulation just behind the shower in the service compartment where the cable comes in from outside. I've already had the shower freeze, so I figured I'd just disconnect/plug it off during winter.
Thanks for any thoughts. From what I read, this is a tried and true product. For me, quality/ dependability trump price.
OWB
2011 F350 6.7L, 4WD, DRW, 8' bed, Reese Elite 25K
2011 Carri-Lite 36XTRM5, MOR/ryde IS, 8K disc brakes, 17.5" wheels/G114s
Solar: 960 watts, 3,000 hybrid inverter, 830 AH bank, 2 controllers
IT: weboost 4G-X, WiFi Ranger Elite Pack
