rear camera monitor
anon125
in our old 2006 sunova the monitor is still cathode ray tube (CRT)
always worked before. today after sitting for a year it showed nothing. vehicle has about 20K miles on it.
pushing on/off got some light flashing on the tube.
what does a new modern one cost? maybe it is the camera of course.
as everything is Chinese made junk is there a least bad model?
voyage observation system VOM-7SN
thanks all
20 REPLIES 20
anon125
$650 later we have the monitor working.
thanks
anon125
lc0338 wrote:
replacement kit
okay we have the kit.
does anyone have a picture of it replacing our old monitor that hangs from the ceiling?
I wonder where the aluminum bracket is supposed to go.
thanks all
anon125
I saw nothing obviously wrong - it goes to the tech next wwek.
thanks
ddndoug
Were you able to find a cure to the ailing monitor system?
Doug
2009 Four Winds Hurricane 33T
F53 Ford Chassis w/Triton V-10
anon125
Thanks
Flyfasteddie
anon125 wrote:
IF we have to replace the old monitor...
it hangs from the ceiling.
do modern ones have that feature? of course it is where the wires are.
thanks
I mounted mine from the ceiling which puts the monitor upside down but there is a "flip" setting that inverts the picture. I think most do that but I'd verify to be sure.
anon125
thanks
anon125
AHA will do. thanks
ddndoug
Before you start replacing parts, check to see if the connection came loose on the back of the monitor. From what I understand it's quite common for the manufacturers to "forget" to put on a clip that prevents the wire from working itself loose on the Voyager systems.
Doug
anon125
lc0338 wrote:
Got a relative in USA?
no.
thanks
lc0338
anon125
387.43 USD = 500.40 CAD
Plus whatever the credit card charges plus import duties plus shipping!
lc0338
anon125 wrote:
lc0338 wrote:
replacement kit
cad$500! ouch!
but noted.
thanks
387.43 USD
anon125
thanks all
