โNov-21-2020 04:57 PM
โJul-26-2021 03:16 PM
BFL13 wrote:
I don't have a for sure answer on the wifi for a long 5er.
I was able to walk about 100ft back from the back window camera and still see myself on the iPad. I was able to go out front of the MH about 20 ft and still got the picture from near 50ft, but off to the side with more MH in the way, not the front window see right through, I lost the signal. However, I got behind the truck with camper on it with the front of the truck to the back quarter of the MH for about 35 ft or so and got the signal.
It goes with line of sight but also with barriers in the way what you get. I think at 50 ft it might be spotty, hard to know.
Discovered it has a time delay if that matters for a rear view. I could see myself move and stop, and the picture caught up after I stopped. I counted one, two, but before I said two it caught up.
I mounted the camera on a piece of wood and can move the piece of wood between RVs. You don't need two of the OEM holders.
โJan-15-2021 07:13 AM
โJan-15-2021 06:10 AM
BFL13 wrote:
I tried to tether the Nokia 2.1 phone to the iPad using a USB hub to connect the two cables that charge each device, and I couldn't get it to work like I can with the phone and laptop.
โJan-15-2021 06:03 AM
BFL13 wrote:
Would this thing do the job? It has three modes, but I am confused whether it needs wires as a repeater.
https://www.amazon.com/1200Mbps-Extender-US754-Amplifier-Extender/dp/B08NZGJFT7/ref=sr_1_5?crid=3TC6...
โJan-14-2021 10:11 AM
โJan-14-2021 06:14 AM
โJan-14-2021 05:59 AM
โJan-14-2021 05:55 AM
โJan-14-2021 04:37 AM
BFL13 wrote:
I have looked at wifi extenders (lots of those) but can't make out how they can pick the right wifi signal to extend by wireless and then relay that to the farther along device. Some(all?) have LAN from the extender back to the first wifi source box and then they wifi from there, (I think)
โJan-13-2021 05:40 PM
โJan-13-2021 05:02 PM
BFL13 wrote:
My cell phone says it can do "hotspot" or tethering. Would that work as a "booster" for the camera wifi in a long trailer/long truck? (where it is too far for the wifi now)
Eg, I have an iPad on the truck's mirror and the camera at the back of the RV. If I use the cell phone in the front of the RV with the Hopkins app to get the camera's wifi (so it is free that way NOT using "data"),
and turn on the cell's "hotspot", would that give the signal to the iPad it could select as its "network" in the truck for that extra distance?
EDIT--the cell seems to have its hotspot with Bluetooth. I have a question about this idea or another booster in to Hopkins. I will pass along any info.
โJan-11-2021 12:35 PM
โJan-10-2021 12:05 PM
โJan-10-2021 12:03 PM
