โNov-03-2013 12:47 PM
โNov-04-2013 06:58 AM
pianotuna wrote:
Hi nine,
The usual number quoted is about 30 to 36 amp-hours for running the fridge on propane, and all other parasitic loads.NinerBikes wrote:
How many amp hours do you think that fridge and propane detector draw in a 24 hour period?
โNov-04-2013 06:29 AM
โNov-04-2013 06:08 AM
โNov-04-2013 05:34 AM
christopherglenn wrote:
Where things get exciting is if you are closer to 90% SOC, then several hours of clear sun can get expensive.
โNov-04-2013 05:23 AM
Not much. The 120 watt panels at 17.2 volts generate just under 7 amps, 225 AH @ 75% you are down 56 amps. In theory you will need 8 hours of direct sunlight just to fill the bank. With the fridge and propane detector running at the same time you are likely closer to 10 hours. On a cloudy day you may be seeing 30% output - which doesn't matter, as there isn't 10 hours of daylight anyway.
โNov-04-2013 04:23 AM
โNov-03-2013 09:23 PM
โNov-03-2013 06:03 PM
โNov-03-2013 04:22 PM
โNov-03-2013 04:11 PM
NinerBikes wrote:Voltage will probably be low anyways from the clouds so more than likely no problems.
If I bypass the controller, and run straight off the set of 120W panels on that cloudy day only, what's the worst case that can happen running straight from the panel to the battery on that cloudy day?
โNov-03-2013 03:55 PM
โNov-03-2013 02:28 PM
โNov-03-2013 02:22 PM
โNov-03-2013 12:54 PM
