โJun-09-2016 08:55 AM
โJun-10-2016 05:57 PM
GordonThree wrote:BoonHauler wrote:
Anyone using a thermostatically controlled switch to turn the fan/s on and off?
Any links? How are you controlling the fans/s?
There are simple 12v thermostat modules on ebay and ama zon ... the poster using the fixed thermostatic cut-out switch found a great solution too, can't beat that for simplicity.
I'll be using one of these, a multi purpose module I designed myself
It's a WiFi connected DC switch, that also supports data collection. So I can monitor temperatures, adjust the on/off settings, using my cell phone. It has two outputs, so in theory I could use number one on fans for summer cooling, and number two on a relay and 40 watt light bulb for winter heating.
โJun-10-2016 09:30 AM
โJun-10-2016 07:48 AM
โJun-10-2016 07:36 AM
โJun-10-2016 06:57 AM
Baja Man wrote:beemerphile1 wrote:
I would suggest that before you go messing with fans you should insure the refrigerator is installed correctly. Your manual will have very explicit directions about spacing and clearances, these directions are often ignored by the RV manufacturer.
Sometimes adding baffles or closing off a dead air space above the refrigerator is all that is needed to optimize function.
beemer....
I agree with the installation info. I reviewed the install manual and it states that there should be 1" max space behind refer. This is basically almost kissing the coils.
My space is more like 6". I'm sure this added space has the effect of more hot air hanging around coils, which means longer times for air to rise and exit roof vent and also equals more hot air warming coils.
Less space means less hot air around coils, air rises quicker as there is less of it, and ultimately cooler coil.
Is this logic about right?
Also, can I decrease the space down to 1" without removing the refer?
If so, how? Can I glue blocks foam against RV sidewall until I reach the 1" gap between the new wall of foam and refer?
Thoughts?
โJun-10-2016 05:10 AM
โJun-09-2016 11:17 PM
โJun-09-2016 08:46 PM
โJun-09-2016 04:13 PM
โJun-09-2016 02:44 PM
landyacht318 wrote:
I have one 120Mm delta fan which is ridiculously powerful at 252CFM and at about 50 watts, but it cannot be slowed below about 35 watts via PWM or voltage control, or it just shuts down. Much too loud and powerful for normal use, and its impeller will easily chop off a fingertip.
โJun-09-2016 12:27 PM
โJun-09-2016 11:57 AM
Baja Man wrote:
I, too, thought about the fans used to push air out the side vent, but....
My research on the subject indicates that the air should be moved up and out of the roof vent. Fans installed so that they move/push air upwards. Heat rises so this makes sense.
Thoughts?
โJun-09-2016 11:43 AM
โJun-09-2016 11:38 AM
โJun-09-2016 10:44 AM
