Refrogerator Problem
Grey_Mountain
Our Norcold 1200 fridge will not run off propane or generator. Workds fine on shore power. Had this problem last year; RV fixit guy checked it out, said it was working fine. Nopo.
Any suggestions? Still considering switching out with a residential fridge.
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
16 REPLIES 16
Grey_Mountain
Fridge is now working as it should.
Thanks for all the replies and suggestions.
GM
Honda CR-V Toad
English Bride
Grey_Mountain
Got the unit back yesterday. Fixit folks replaced all four batteries; replaced the Xantrax Freedom 458 inverter. Apparently the issue with battery charging and also with the fridge are inter-related. I am checking the unit now to make sure everything is working as it's supposed to.
GM
Honda CR-V Toad
English Bride
Puddles
belairbrian wrote:
Tyler0215 wrote:
Those darn refrogerators
Yeah, when they break, what is an evil witch to do with a handsome prince.
Seriously, though. Sounds like maybe you only have 12v to the control circuits on shore power. Not sure why that would happen but as said Shore A/C and Generator AC should be the same. No 12v when on battery would stop propane from working.
Spelling critics, remind me of those kite eating trees... they are everywhere!
HTML
maillemaker
Why would a bad breaker in your inverter keep your fridge from working on propane?
I would think a bad breaker would stop providing 110V to the fridge, but could still be providing the 12V it needs to run on propane.
But, you should have this problem on shore power or generator.
And, you can easily test by testing for 110V at the refrigerator plug, and by flipping the breaker to ON.
On shore power or generator power, with the fridge breaker ON, you should have 110V at the power socket where the fridge plugs in.
On my rig you can access this socket behind the outside access hatch.
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
Grey_Mountain
All I know is what the Fixit Guy told me. As I have stated before, when it comes to issues such as this, I am an excellent wood worker.
GM
Honda CR-V Toad
English Bride
STBRetired
Sorry, but that makes no sense. Why would a bad breaker in your inverter keep your fridge from working on propane? The inverter should have nothing to do with your fridge. Your inverter should be in pass thru mode when on shore power or if the generator is running.
The inverter may indeed have a bad breaker, but replacing / repairing that will not solve your fridge problems.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Grey_Mountain
RV Fixit guy says I have a bad breaker in the inverter. That is what is causing the fridge problem. Options are to ship the unit to Xanax to be fixed or replace it. I opted to have it replaced.
GM
Honda CR-V Toad
English Bride
dougrainer
ALL you have to do is fire the Genset up, open up the rear Access door to the refer and plug in a 120 volt light or appliance to the 120 refer receptacle. IF the Appliance operates, your Transfer is OK. IF the Transfer was a problem 1/2 of your 120 electrical in the RV would be dead. Doug
Grey_Mountain
"Refrigerator" is a copywrited trademark and can not be used willy-nilly. That's why I compromised with "refrogerator."
Anyway, gimmee a break. I'm just a poor Injun tryin' tomake his way in a white man's world, what with a mission school education and a reservation upbringin'. What d'ya expect anyhow.
Send me free stuff. Preferabley a new refrig..., ah, a new refrogrator.
GM
Honda CR-V Toad
English Bride
Grey_Mountain
RV fixit guy says it may be a transfer switch issue. Taking it in in a few weeks.
I think I got metric gremlins in the electrical system last time I went to Canada.
GM
Honda CR-V Toad
English Bride
doxiemom11
Could be a bad circuit board. We have had our work on electric and generator, but not propane. The circuit board was the problem. Replaced and all worked fine.
Old-Biscuit
When on generator check that you have 12VDC ......NO DC/No workie on AC or propane
ajriding
Your generator must have electrical issues.
No flame from propane could be many things.
could be blocked tubes between the tank and the flame.
Could be wasp got in
could be a bad regulator
or a sensor went bad
or the thermocouple is bad or bent
lack of DC power to fridge
blown fuse
blown circuit board
could be fridge is on the last leg - the AC power might make more heat than the gas flame (did you confirm you do not have a flame) and the flame is just not enough to do any good.
belairbrian
TV 2007 Chevy 2500 Long Box Vortec 8.1/Allison or 2016 Tundra Crew Max 5.7L 4x4
2022 Freedom Express 192RBS
Equalizer 4 way WDH, Prodigy 3 BC
USAF Retired
WAR EAGLE
