Repaired Spring Hanger Brackets: Now What?
CavalierTwo
First Post On RV.Net.
I recently returned from a round trip to Alaska. Driving 11,444 miles on some of the worst roads in Canada and Alaska. Due to road heaves (from freezing & thawing constantly) creates a real road hazard. I had both rear axle spring hangers break, then replaced and welded. The bummer of it was, I had to have it done a second time. The second time I had reinforcements installed. So 1 1/2" tubing was welded from hanger to hanger on both axles on my 2017 Reflection 26RL 5th wheel.
Now my question: Should I have an inspection on the entire frame, suspension & axle to see if there is other damage?
16 REPLIES 16
Michelle_S
I think you'll be very happy with the MOR/Ryde IS upgrade.
I try to tell people that yes it's an expensive update, but look at all the money and down time spent on all the different "Band Aide Fixes". Bite the bullet once and be done with it.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
GD310GK
We belong to a few Grand Design sites on Face Book and we have noticed sooo many folks with 2020-2022 models that have had the springs break and damage the 5th wheel. A few were lucky to notice the broken springs before any damage occurred.
We want to travel to Alaska with ours and decided to have a MORryde independent suspension and disc brakes installed. We have an appointment next month. As we have already sunk quite a bit of money in this 5th wheel, and this is going to be the last RV we own, we decided to not attempt fate and get it 'beefed up' for the trip to Alaska and other trips.
We watch the Face Book pages and when we notice a common problem in the 5th wheels, we'll inspect that on ours and more often than not, we can tell ours would have the problem at some point. We've been very proactive in 'fixing' things before they break. Hopefully everything we've been doing to it will give us more peace of mind while traveling.
JBarca
Nomad II
Nomad II
Yes, I know, maybe it can help someone on the future reading the post. Having lower I beam flange damage is not going to get better unless someone helps it.
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
Grit_dog
Navigator
Navigator
OP was 1 n done....
JBarca
Nomad II
Nomad II
I know I'm late to the party, but for sure make sure your shop checks these area's at a minimum.
The wheel and axle alignment.
The lower flange of the main frame rails I beam. Look specially just past the rear spring hanger and the front spring hanger. You are looking to see if "any" distortion of the lower flange of the I beam is present. The heavy rear overhang behind the rear axle can create a localized overload after a series of major up and down bumps. The lower flange has to be able to withstand this. While your frame may not be very bad right now, if the lower flange is weakened, then over time of normal frame flexing and the miles go by, the back of the camper will start to slowly bend down. Over time, the rear slides may start having issues as the opening in the camper is no longer square, it sagged into a parallelogram. The entry door may do this too if it becomes hard to fit into the frame.
If you really want to see how good or bad the sag is now, pull a string tight down the length of the bottom of the frame. It is a good idea to create a baseline now of the frame in it's flexed state. Measure the deflection and record it. The axle area between the spring hangers most likely will be straight. The rear section may be sagging down hill in relation to the axle area, and the front of the axle may also be at a slight bend down towards the front of the camper compared to the axle area.
If this lower flange damage exists, suggest you get the frame reinforced now before the long term bending occurs. It is much harder to fix the issue when the slides will no longer go in and out. In the RV world, they call the sagging rear overhang of the frame, structural loss of frame camber.
Also have them check the web section of the I beam above all 3 hangers, each side, for fine rust lines of the starting of a crack in the web section.
The last Grand Design higher end model travel trailer I saw, (10K GVWR trailer) they added extra reinforcement on the lower flange on the long rear over hang from the factory. This was a 36 ft camper, and a TT, dual slides in the back, the rear overhang on that camper is longer then yours I do believe. I'm not sure what yours would have, they may not have added that extra reinforcement due to a shorter rear overhang.
They should also check what they can of the pin box area and the steel connecting the main frame rails to the king pin box.
The abuse your camper frame took from those roads, is large damaging force to a RV built trailer frame.
Let us know how your inspection come out.
Hope this helps
John
wa8yxm
IS an inspection needed.. I do not know.
Would it make you feel better, Likely lower your blood pressure and stress levels. ABSOLUTLY
And thus it's worth it.
NOW... If it finds a problem .. Make that worth it squared.
joebedford
Nomad II
Nomad II
Somewhat by accident, I discovered that a couple of frame cross-members were broken. If more let go, the frame rails could have flopped over causing a total write off of my 5er.
Yes, get it checked out, but I checked mine out without help.
pianotuna
Nomad III
Nomad III
Hi,
I had springs fixed. The shop did not do an alignment. Now I need new tires.
Regards, Don
Lwiddis
Peace of mind is important to me. I’d get the inspection!
BarneyS
Moved to Tech Issues forum from Towing.
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
CavalierTwo
Thanks all for your input. I'll be looking up suspension specialist to get it checked out.
Thanks Again.
valhalla360
Nomad III
Nomad III
Probably worth it if there were multiple issues and had to re-repair some of the fixes.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
RAS43
Yes,
I would suggest you find a commercial vehicle repair shop and have them inspect everything and then have the alignment checked/aligned. It is worth the cost IMO.
CavalierTwo
My Tow vehicle is 2015 F250 Powerstroke. My load is around 10K.
And yes those heaves do sneak up rather quickly.
