Apr-09-2019 09:17 PM
Apr-13-2019 10:47 AM
Apr-13-2019 10:43 AM
jodeb720 wrote:The Stanley 40 amp charger is basically the same as the 1093 (read my previous post). It is a smart charger that will shut off automatically and will not boil the batteries.
OP Here,
My cousin is strictly a weekender camper. No long term/week at a time kind stuff.
His need is to have lights, water pump, recharge cell phone and a ceiling fan of some kind.
What he currently has is a battery tender with a 2 amp maximum output. If he makes the investment moving to a pair of GC's from Costco, then he'll want charging system that he can connect when he gets home from the weekend to recharge the batteries.
I thought I knew a thing or two about recharging, but as you've (collectively) pointed out, short of using a hydrometer, it's a **** shoot in terms of what is a fully charged battery.
personally, I've got my 1093 and I have two sets of gc's with a select-able cut off switch so I keep one bank feeding the house, and one bank can be charged, offline by the 1093.
The one thing I've not done is gone after the batteries with a hydrometer to check SOC.
Back to my cousin - so short of him spending a few hundred dollars for a megawatt or meanwell - the stanley will probably suffice.
My biggest concern is him overcharging the batteries and boiling them to death.
In a way, it's better to undercharge than to overcharge in this case.
Thanks for all the help!
josh
Apr-13-2019 10:02 AM
Apr-13-2019 08:18 AM
Apr-12-2019 07:57 AM
BFL13 wrote:RLS7201 wrote:
Keep it simple. Harbor Freight 2/10/50 Battery charger. Item # 66783. On any one of the 3 settings, the charger will shut down when it reaches 14.4 volts and turn back on at 12.8 volts. On sale for $29.95 4/12-4/14.
Hook it up and walk away.
Richard
So the battery is at say 75% SOC when it reaches 14.4 volts, and now the charger quits until voltage drops back to 12.8 volts? Great! 😞
Apr-12-2019 04:50 AM
MrWizard wrote:Stanley bought out B&D, in talking to one of their engineers they told me that the Stanley 40 amp charger was based on the B&D charger with better controls and charging algorithms.
Gjac
we all like the BD/vector 40amp charger
its just NOT being Mfg anymore, used ones IF you can find one for sale
command a 'as new' price
i have no experience with the Stanley
Apr-11-2019 12:25 PM
Apr-11-2019 12:03 PM
Apr-11-2019 08:59 AM
Apr-10-2019 07:44 PM
Apr-10-2019 07:03 PM
Apr-10-2019 07:00 PM
jodeb720 wrote:
I'm going out on a limb, but I'll bet he'll end up with a set of GC's and will need a way to recharge them when he gets home to full top them off.
Apr-10-2019 04:50 PM
Apr-10-2019 04:02 PM
When the battery is fully charged and registering 100% on the Charge Meter, a small charge will continue to move from the charger to the battery. If the charger is not disconnected from the battery, eventually heat build up will cause the battery acid to boil and overcharge the battery causing damage to the battery. Monitor battery charging progress constantly and if battery gets warm, stop charging it immediately.
Although this charger has an automatic cut off; do NOT depend solely on automatic cut off. Leaving charger unattended can result in fire and property damage.
