โDec-29-2021 05:00 PM
2018 RAM 3500 Dually 4x4 crew cab
,โJan-03-2022 11:34 AM
โJan-02-2022 04:55 AM
ajriding wrote:
I still cringe to think dear old dad towing the family trailer with the station wagon equipped with 4 drum brakes, on the car, not the trailer, none on the trailer.
,โJan-01-2022 04:23 PM
โDec-30-2021 06:01 PM
Jethroish wrote:
Follow up:
After another quick check of things (adjustments, elec connections and voltage), along with finding 2 elec brake distributors to chat with, I am going with the magnets are just worn out. The wear hole indicators are either gone or barely visible. This trailer rolls 10k to 12k miles per year at 12k to 13k pounds, so I guess it is no surprise.
IMO, I highly doubt the brake assemblies are meant or expected to last that many miles. Realistically, unless you are a full timer, most TTs or 5ers probably do not see 30k miles in their life time.
โDec-30-2021 05:39 PM
โDec-30-2021 07:36 AM
โDec-30-2021 07:14 AM
,โDec-30-2021 07:02 AM
โDec-30-2021 05:28 AM
wa8yxm wrote:
Though it is possible for a turn. or several turns, to short out the only thing that would WEAKEN the magnets is a bad electrical connection.
Measure the resistance brake lead to ground. Look up the magnets
If the resistance is too high. Bad connection
Too low, Shorted coils.
Note plus or minus 10-20 percent is "normal variation"
โDec-30-2021 04:42 AM
Jethroish wrote:
Could not find anything on this here.
I have a horse trailer with dual 7000# axles. I suspect the brake magnets have weakened. Visually they appear good, but with the brake controller set at the highest setting, only one wheel will lock up on the gravel driveway. Trailer is about 8000# empty. I have adjusted the brake shoes out and they lock up with the trailer off ground.
I know things wear out and eventually need replacing.
Anyone here ever have a similar experience? Did you change out the brakes with a full assembly that included new magnet?
The brakes on the trailer are original (2015 model). Rough guess is the trailer has been towed approximately 60,000 miles in 6 years.
โDec-30-2021 02:56 AM
โDec-29-2021 08:01 PM
โDec-29-2021 07:15 PM
,โDec-29-2021 06:53 PM
time2roll wrote:
Not that expensive to replace the complete assembly. For superior braking I recommend going to disks.
