โMay-28-2015 07:41 AM
โMay-29-2015 04:28 PM
โMay-29-2015 03:10 PM
โMay-29-2015 02:03 PM
โMay-29-2015 01:33 PM
lanerd wrote:Hermes wrote:
Thank you for the input. Ron, by residential AC some manufacturers are using the term referring to cold air returns as opposed to the standard RV AC units which are noisy.
Ok, you got me here. I'm not sure what you mean by "cold air returns". Can you explain this to me please?
AC units only cool existing air from inside the rv (or house). I've never heard of one that will take outside air and heat/cool it. My mh has intakes on the ceiling that takes the interior air, runs it through the AC unit to either heat it or cool it, and then returns it back to the interior of the rv. My home AC units does exactly the same so I don't think it makes a difference (in the process) whether the AC is on an rv or house.'
Ron
โMay-29-2015 12:23 PM
Chris Bryant wrote:
I believe he is talking about ducted return- Newmar has had it for a long time, others are coming out with it now. Makes it *much* quieter (and much harder to service ๐ ).
Dometic has come out with what they call The Quiet Zone
โMay-29-2015 11:31 AM
โMay-29-2015 10:28 AM
โMay-28-2015 01:42 PM
pianotuna wrote:
Hi,
Add some solar panels, in fact if you full time populate the entire roof with panels.
Consider going to a 24 volt DC system with a DC to DC converter for the 12 volt side of the unit.
The biggest hassle of a propane fridge is the need for the RV to be almost perfectly level. They are expensive to operate on the electric setting, which doesn't matter--unless you are in an RV park that meters the power.
When the fridge finally fails, I will replace with a residential unit.
โMay-28-2015 01:11 PM
rr2254545 wrote:
Two necessary items - yes residential electric fridge and stacked washer and dryer
โMay-28-2015 01:01 PM
โMay-28-2015 10:25 AM
โMay-28-2015 10:07 AM
โMay-28-2015 09:48 AM
โMay-28-2015 09:45 AM
