โJan-24-2018 07:22 PM
โSep-16-2018 05:29 PM
โJan-28-2018 09:34 AM
dieseltruckdriver wrote:burningman wrote:
Buying the โCompanionโ EU2000, or passing up a deal on a regular EU2000 is ridiculous.
The Companion is no different other than having THE WRONG 30-amp plug mounted on it and it costs $100 more. Why would you do that?
Itโs so easy and so cheap to make your own parallel box, and there are a bunch of write-ups on it.
I like making them with an outlet box, an RV-30 receptacle, a face plate, and two 12-gauge power-tool replacement cords. The factory parallel kit is extremely overpriced and still is t what you need.
You do have a possibly unsafe condition doing it that way.
The way I did it was to buy the parallel cord kit, cut it in half and connect them to the RV 30 amp outlet in the box.
It is still not idiot proof, but I can unhook one generator and still have power to the camper and not worry about someone grabbing the end.
โJan-28-2018 09:32 AM
Butch50 wrote:ktmrfs wrote:
But now there are the power saving AC units from Coleman and Dometic that drop the running current by several amps, very likely enough to use one honda 2000 even at 5000ft or so. I've run a coleman power cub with a 10A running current for hours on end at 8000ft with no problems on the honda 2000.
Do you happen to now which Dometic A/C work at lower current? My A/Cs are both Dometic. The 13,500 bedroom unitis a low profile and my RV was built last Sept. I have the sheet that the manufacturer sends with the units model # that they installed but the model # they have listed for my unit does not exist. There is one unit on Dometic site that is one number off in the middle of the model # so this might be it.
โJan-28-2018 09:07 AM
โJan-28-2018 07:48 AM
โJan-28-2018 07:40 AM
โJan-28-2018 07:29 AM
โJan-28-2018 04:37 AM
burningman wrote:
But this one is being purchased for an RV, and the twist lock is the wrong outlet.
โJan-28-2018 04:12 AM
โJan-27-2018 09:40 PM
ktmrfs wrote:
very true. the RV 120V 30A is the "odd man out" connector system. the twist lock is the standard 120V 30A outlet. Try finding an adapter that would go from 30A female RV to 30A female twist lock. If they exist, they are very hard to come by. There is a reason there are so many 30A twist lock to 30A RV adapters. The 30A RV is only NEC approved for RV use, nothing else.
โJan-27-2018 07:32 AM
The Companion's 30 amp receptacle is only "wrong" for RV use but it's not sold solely for use by RVrs, rather it's intended to be used as a general purpose portable generator by anyone for a variety of purposes and as such the Companion's 30 amp twist lock receptacle is entirely correct. For dedicated RV use there's not really any advantage to buying a Companion as it's 30 amp twist lock receptacle has to be converted to a TT-30 receptacle anyway.
โJan-27-2018 06:08 AM
โJan-27-2018 05:54 AM
โJan-26-2018 12:43 PM
Coleman Mach 3 P.S. compared to Coleman Mach 3 Plus ... same cooling ability but much lower continuous draw for the former would make powering this unit with a 2K genset much easier. :B
