โJun-28-2020 10:58 AM
โJun-30-2020 09:21 AM
โJun-30-2020 07:38 AM
โJun-29-2020 11:06 AM
โJun-29-2020 10:47 AM
ajriding wrote:
I had a 5.9 with a truck camper and trailer climbing the Rockies and temps stayed level. On big climbs temps would rise, then the thermostat would open, then cool back to high 180's, then close and rise into 190's and cycle back and forth (I had a quality temp gauge so could see this).
I never saw temps go high.
I suspect other issues,
A bad radiator - old and partly clogged- a mechanic shop can look at it with a temp gun and see if there is any clogs.
A bad fan clutch (slower speed climbing might require the fan to run)
A bad thermostat
Is the fan shroud intact and directing air correctly?
Nothing blocking the radiator?
โJun-29-2020 07:52 AM
โJun-29-2020 06:41 AM
Flan wrote:
What are you considering hot? 210 degrees for short stints is pretty normal usually once cresting the grade they will cool off settle back in around 180-190.
โJun-29-2020 04:13 AM
โJun-28-2020 08:26 PM
garym114 wrote:
Don't know where the power RPM range is on your engine but it is probably higher that the RPMs you were doing at 30mph in third gear.
โJun-28-2020 08:09 PM
Berkyeng wrote:
Thanks.
Is there any way to access this from under the coach (knowing full well this will get me wet and dirty!). Iโve been under the bedroom once and the engine cover is so tight it took me 2 days of prying and pounding to get under the bedroom. I really donโt want to go through that again!
Thanks.
โJun-28-2020 08:03 PM
โJun-28-2020 11:14 AM
โJun-28-2020 11:07 AM
