โFeb-10-2018 08:06 AM
โMar-21-2018 11:07 AM
โMar-21-2018 10:22 AM
ScottG wrote:2oldman wrote:
OK, yes, parallel batteries might do better separated. Series, no.
Remember, the discussion is about using two chargers. Trying to use two smart chargers for either parallel or series batteries never works well if the two chargers are in parallel.
โMar-20-2018 12:56 PM
2oldman wrote:theoldwizard1 wrote:You don't really have to separate them.. do you?
If they are both smart chargers, separate the batteries and charge them independently.
โFeb-13-2018 01:41 PM
โFeb-13-2018 12:11 PM
โFeb-13-2018 11:50 AM
BFL13 wrote:
The newer Parallax ones have PF correction though. They cost more than some others ISTR. Also they have voltage settings in the low 14s unless that has changed.
โFeb-13-2018 09:46 AM
โFeb-13-2018 09:16 AM
5475TC wrote:
Specifications
AC Input :
105-130 60Hz
AC Input Watts:
1260 <--------The 5475 benefits from an extremely efficient feature of operating on a standard 15 amp outlet.
Amps:
75 amp
Dimensions:
3-5/8โH 8-3/8โW 11โL
Listed:
ETL Listed
Special Features:
TempAssure standard, standard 120VAC 15 amp line cord, steel enclosure with durable powder coat finish
Replacement Upgrade?:
Yes
Series:
5400 Series
Temperature Compensation:
Yes
Type:
Deckmount Converter
Weight:
7.75 lbs
โFeb-13-2018 09:13 AM
โFeb-13-2018 08:49 AM
Cydog15 wrote:
That's just not true.
โFeb-13-2018 08:00 AM
โFeb-13-2018 07:37 AM
โFeb-13-2018 07:17 AM
full_mosey wrote:ktmrfs wrote:Dirtpig wrote:
I feel like it would be much less of a hassle to just upgrade your converter/charger to a 75amp/100amp model. No Mickey mousing clamping or disconnecting batts. Just my 2c.
well, since I have a 2000VA generator, it will NOT run a 75 or 100A charger. so, I have a 55A charger in place of the WFCO and a 65A in the pass through. when only on one generator, on goes the pass through 65A. when I have shore power or two generators then I crank them both on and get 110A or so for quite a while.
So, there are reasons to have two chargers rather than one.
and there is no mickey mouse stuff, I just turn one or the other on or both on. both are connected to the same battery bank in parallel.
75A on 15A line, 1260W.
Any good?
HTH;
John
โFeb-13-2018 03:48 AM
