โJul-02-2016 09:56 AM
โJul-05-2016 12:18 PM
Mile High wrote:forumcoach wrote:That did the trick, Perfect! Thank You!
I would try to program the thermostat first.
Turn the thermostat off.
Hold down the up and down button together for about 5 seconds until words are on the screen.
Go to zone 1.
Mode through the different settings for the Zone.
Switch to Zone 2 and mode through the different setting options.
Switch to zone 3 and mode to correct setting.
Once all three zones are set turn the switch to heat or cool and then back off.
This will exit programming mode and save your settings.
I believe Coleman asks you to remove the tstat cover for this procedure, but I do not recall having to do that for any of them I have run into.
I actually was able to program zone 3 for a heat pump, which I didn't have before. not sure if it has a heat pump, but that would be cool if it did!
โJul-05-2016 08:59 AM
Go to zone 1.
โJul-02-2016 06:51 PM
